Old 10-29-2009, 12:51 AM
Fastermouse Fastermouse is offline
Default How do you pros compensate delay
I have watched some vids on manual compensation, and I know some nudge and some use time adjustment, but, all you guys that are constantly working big projects... How do you do it?
Old 10-29-2009, 01:01 AM
KingFish KingFish is offline
Default Re: How do you pros compensate delay
Mellowmuse ATA is the only "Simple " solution to delay Compensation in LE - any other methods are to use the manual Time adjuster plugin, and ping a;; of your tracks for the right value.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 10-29-2009, 01:05 AM
So can I completely trust ATA? I hate to spend the $$ and still have to work around.
Old 10-29-2009, 01:09 AM
well its a learning curve - but once you figure out the workflow... it works.
it's not an "Along the way" solution to leave active while tracking etc...
Only really to be applied for final mixing - make sure you watch a few videos before you spend the money.
David
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
Old 10-29-2009, 01:38 AM
spicemix spicemix is offline
I use the Logic plugin.
Peter Jensen
spicemix
Old 10-29-2009, 02:13 AM
So, if ATA works, then why hasn't Avid made this a standard plug-in or a clone that is included w/ PT to deal with our number one bitch?
Old 10-29-2009, 02:29 AM
Would you rather leverage that demand to sell a kludge for $49 or make people buy a whole new system for $$$$?
Peter Jensen
spicemix
Old 10-29-2009, 02:35 AM
SeedGuy SeedGuy is offline
I tried ATA, and couldn't be bothered with the messing around. It's not so bad on simple projects, but as soon as you start adding subgroups and multiple sends it starts taking a bit of time. Although I have to say it's a good product for those who have the patience.
FWIW, I find nudging the audio a much simpler solution.
Old 10-29-2009, 03:52 AM
Loudnoize Ent. Loudnoize Ent. is offline
Same here.. Gave it a go and couldn't be bothered. I prefer nudging as well. Just reading all these threads the last couple days about ADC is certainly an eye opener for those of us, not wanting to dick around with this issue any longer and finding a better solution.
Old 10-29-2009, 07:13 AM
albee1952 albee1952 is online now
I choose my plugins carefully and now don't give it a thought. By knowing which plugins have lots of latency, I simply choose different ones. For instance, I never use a "look-ahead" limiter on a track(or during recording). When mixing, those are okay on the master(but I usually leave all master plugins to a separate step in a mastering session). Honestly, the only time I worry about it is when I use Melodyne and I have a simple method for dealing with that that is dead-nuts perfect.
Unable to compensate delay supersonic1000 macOS 2 10-01-2011 01:38 PM
Delay from Inserts, How to compensate CisumBlue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-24-2010 08:47 AM
Compensate for Delay question Raggi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-30-2007 06:13 AM
compensate delay of UAD-1 plugins on aux-bus? fizzler Pro Tools M-Powered (Mac) 1 09-23-2006 01:23 PM
How to compensate for midi delay surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-02-2001 10:16 AM
