Old 07-24-2021, 11:54 AM
kosmokrator kosmokrator is offline
Default Feature requests..
Hey guys,
great job on the custom mapping!
Just finished a big Atmos mix with the newest software and used this feature extensively. Came in very handy!
I have two feature requests: with bigger plugins finding the parameter to map is not that easy sometimes.
Would it be possible to just touch a parameter on the plugin GUI and then touch a knob/fader on the S6 to assign it? Like with MIDI learn..
And another one would be the possibility to change a meter display from Master Meter Module to 'normal meter' with a softkey and store it in the session.
Old 07-26-2021, 05:28 AM
creativecontrol's Avatar
Default Re: Feature requests..
Glad you are enjoying custom maps - and thanks for the feedback! Can you elaborate a bit please on what you mean by "normal" meter? Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-26-2021, 09:47 AM
EddieJones's Avatar
Switching between Master Meter Mode and Channel meters can only be done in the surface setup page as it does require a lot of re wiring in the background. I'm not saying it cant ever be done but its not an easy task.
I'll look into the mapping request....
Old 07-26-2021, 10:38 AM
Ah yes, Channel Meters. I believe allocating a dedicated CDM for Master Meters is the way to go - and it doesn't have to be physically mounted in the standard location as Channel Meters. Just like the tether some folks use on the MPM and MJM - find an appropriate location and pipe an ethernet feed from the switch in your frame. If MTRX or MTRX studio is involved, these can be used to look at Sources (re-renders, streaming inputs, room patches, etc.) or Output Destinations.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-28-2021, 05:50 AM
thanks guys, appreciate the replies. Understood that meter switching can only be done via surface config at this point. No biggie.
We already have the meter panels in a very unusual location in the Atmos mix room. Some pics here:
https://postproduction.redbull.com/facilities/
I love this layout.
Way better than the standard frame we use with the S6 in the other rooms.
Old 07-28-2021, 06:50 AM
Looks fabulous!
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Feature requests Dopamine Pro Tools TDM Systems (Mac) 24 03-16-2010 12:41 AM
Two feature requests RobMacki Pro Tools TDM Systems (Mac) 13 07-08-2006 03:11 AM
Bugs, feature requests and tip requests! Basil Rush Pro Tools TDM Systems (Mac) 6 12-07-2005 08:21 AM
feature requests for next PT rev Captain Crunch Pro Tools TDM Systems (Mac) 0 07-20-2002 09:56 AM
A few feature requests: uno1234 Pro Tools TDM Systems (Mac) 32 10-12-2001 01:28 AM
