Re: structure crashes 1 incidence
https://stevenslatedrums.com/trigger.../#trigger-free Trigger 2 Free is not compatible with Trigger Instrument Editor, which is required to load your own samples, but if you’re sufficiently impressed with Trigger Free, the full version (Trigger 2 Platinum) is currently on sale for $49 https://stevenslatedrums.com/trigger-2-platinum/ Use the updated Trigger Instrument Editor to design your own multi-velocity, round-robin drum samples to use in Trigger 2 drum replacer, FOR FREE! https://youtu.be/aLWX2alev5c How To Make Your Own Drum Samples (And Load Them Into Slate Trigger) https://youtu.be/FqPV6RbXwTs However, if you want to persevere with Structure: https://duc.avid.com/showthread.php?t=376270 Quote:
https://youtu.be/Z9bwpn77Nq0 Structure – Keyswitching https://youtu.be/nnxFQfxuta0 Structure – Layering Sounds https://youtu.be/hXhdZoSZNbo Structure – Multi-timbral operation https://youtu.be/wcMP0bQXsqk Slice & Sample (Pro Tools Beat Guru) https://youtu.be/IqC3pj3W-KI Can I make a Structure patch with Structure Free? https://duc.avid.com/showpost.php?p=1364422&postcount=2 Avid Knowledge Base – How to Get the Most Out of Structure Free https://avid.secure.force.com/pkb/ar...Structure-Free
Pro Tools Studio 2024.3 |
thanks for all the links.
tikety-boo as Cleaver says.
!#$@@$#! "Do not fear mistakes. There are none." Miles Davis |
Structure crashes PT when loading EXS patches | Hanswurstlsepp | Virtual Instruments | 16 | 09-22-2015 01:04 AM |
Structure 1.1 crashes PT 8.0.4 when click browser | audiojavi | Virtual Instruments | 0 | 08-29-2010 06:41 PM |
Structure crashes when trying to load Gigasampler patches | lkingston | Virtual Instruments | 3 | 05-17-2010 02:48 PM |
8.0.3 on SL: Structure Free crashes PT | fenderrocker | Virtual Instruments | 10 | 04-08-2010 08:32 AM |
Structure crashes PT8 when loading | Hercules98 | Virtual Instruments | 2 | 04-08-2009 09:08 AM |
