Hello,
Running two separate of mac studios with thunderbolt HDX chassis and getting the same error message inconsistently when booting pro tools. Unable to find an Audio Interface attached to the first HDX card. Please check the power and digilink cables and click ok to rescan. Cancel to open the Playback Engine Dialog and select a different device. PT Version 2022.10 Mac Studio (2022) M1 Ultra 128GB RAM I've found an inconsistent workaround which is to either quit and relaunch pro tools / change the playback engine or switch the number of voices from HDX 1 to HDX 3 can kick it in and it sees the 3 HDX cards. Has anyone else seen this and have any idea what might be causing it? Thanks |
There are so many threads about Mac Studio having issues with thunderbolt chassis and HDX.
One of the most common solutions is to have the chassis plug into a Thunderbolt Dock and not directly into the Mac. Feel free to search the forums |
I haven't had any problems yet. I use the Avid Thunderbolt Chassis (one card). Plugged directly in to the Mac Studio.
Mac Studio Ultra / 128 RAM/2TB HD / Avid HDX Chassis / 2 X Sonnet Echo Dual NVMe Thunderbolt Docks w Samsung 970 EVO Plus (6TB) / Avid C24 / Avid 16X16 I/O Analog / Lynx Aurora 16/16 1/O Analog / Dangerous 2 Bus / Benchmark ADC1 www.glasswing.com www.richardsales.com |
Same here. No problems at all.
http://www.merlinsound.de |
I had the similar kind of issue which I was able to resolve by having the chassis plug into a Thunderbolt Dock.
Thanks for your reply, information on this is harder to find than you suggest but thanks anyways for your recommendation on the Thunderbolt Dock, which dock are you using specifically?
Try booting the Mac Studio without the thunderbolt chassis plugged in then turn it on and plug it in, if it still gets the error then reboot with it still attached and see if that works. Sometimes the thunderbolt ports need to be woken up. If it still doesn't work try a pram reset with the chassis turned on and attached that may do the trick.
Mac Pro 5,1 12 core 3.46ghz OS X 12.6.1 Opencore 0.8.6 Pro Tools Ultimate 2022.10 Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac. Midas M32r console. iPad Pro with Avid Control |
The dock solution works. I used OWC Thunderbolt Hub for my Mac Mini M1 and it solved the problem
Pro Tools Studio 2022.9 problems. Please help me | Simonluka | Pro Tools | 16 | 10-20-2022 09:52 AM |
Graphic inconsistencies PT Studio 2022.7 | ChrisRR | Pro Tools | 0 | 09-13-2022 06:32 PM |
Install Issue W10 & PT Studio 2022 | nymills | Windows | 12 | 09-09-2022 02:24 PM |
Pro Tools 2022.4 on Mac Studio M1 Ultra | Selle Sellink | Pro Tools | 30 | 05-23-2022 04:24 AM |
PT 2022 Studio with MBP mid 2012 | NeoAle73 | Getting Started | 0 | 04-27-2022 12:27 AM |
