Old 09-05-2012, 05:44 AM
cocorico cocorico is offline
Default PT 10 doesn't recognize my 002 rack
I just bought an HP Z420 computer, and I'm installing protools 10.2 on it. I use digi 002 rack via firewire card.
I installed the last 002R drivers, and then protools, and protools doesn't see the 002, I get the "no hardware found" error when i launch protools.
The 1394 light in the 002 is off, and it doesn't appear in reproduction/recording devices.
I tried uninstalling protools (leaving the 002 drivers installed), and reinstalling everything (protools, then drivers) => no change.
Any ideas?
Thanks folks
Old 09-05-2012, 03:43 PM
Default Re: PT 10 doesn't recognize my 002 rack
What firewire controller does the computer have(usually, only a TI chip will work)? Next, which FW driver are you using. There are usually 3 available drivers(when you click on "Let me select from a list"). Avid recommends the Legacy driver, which I would try first. If that doesn't work, try the TI Compliant driver(which works for my 003 controller). The 3rd choice( I can't remember) would not allow my interface to be seen at all(so it may be what you are running).
Old 09-09-2012, 01:42 AM
I' been in contact with the avid technical suppor. We tried, as you say, changing the drivers, but no change. They recommended me to take the unit for a revision, so I took the digi 002 to my reseller.
They told me that a lot of digi 002 units had a bad quality power supply and internal cables, so the units stop communicating with the PC after a while. They say it's a knows issue, they changed the cables and power supplies in decens of digis 002 (in fact, avid recognized there was a problem with these components and covered the replacement until some months ago, much later the warranties expired).
In my case I was lucky, my power supply unit was a "good quality" one, so I just have to change the cables.
When I bring the unit home, I'll inform of the results. Cya!
Old 09-09-2012, 02:22 PM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Try the other port, back on the 002R firewire cord.
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 09-09-2012, 04:43 PM
dave911's Avatar
dave911 dave911 is offline
Usually no need to change anything, just take off the PS connectors and clean them.
Caig audio "Doxit" is a good cleaner.
Can't get PT to recognize my Digi002 Rack JRup Windows 11 08-06-2012 08:35 PM
PT9 won't recognize Digi 002 Rack btovsky Pro Tools 9 32 12-10-2011 08:15 PM
New 003 Rack/PT 7.3 Install Won't Recognize Rack DaveYaffe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-21-2010 01:44 PM
003 Rack does not recognize it's own MIDI Ports! xx1messxx MIDI 0 12-30-2009 06:05 AM
002 rack does not recognize Baby HUI Twain Recording 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2004 07:21 PM
