Old 07-23-2008, 04:17 PM
Mike Borok Mike Borok is offline
Default How to change click track sound?
When I click the "C" button under Inserts, a window opens that control click parameters. There's a long dropdown button that says <factory>; if I click it, it gives me a choice of other sounds, e.g. cowbell 1, 2, 3, etc.
Suppose I want a different sound - say a sidestick or shaker. How do I add this to the list? I assume it's a matter of adding some type of audio file to some folder...
Mike
003 Factory PT LE 7.4
Intel Core 2 CPU 6320 @ 1.86GHz
Gigabyte Technology G33M-S2H
2GB DDR2-SDRAM
XP Home 5.01.2600 (Service Pack 2)
Old 07-23-2008, 08:01 PM
Default
Pro Tools Menus>Setup>Click/Countoff... 'Output' to a desired VI.
filosofem
Old 07-24-2008, 09:19 AM
Default
I tried routing 'Output' to Microsoft MIDI Mapper, but I don't think a MIDI pulse is being generated... I connected a MIDI cable to MIDI Out 1, but the MIDI Out 1 light is not lit (and I get no sound from the MIDI device). I tried routing from the device's MIDI out to the 003 MIDI In, and that works fine ... the MIDI lights are lit.
Is there something else I need to do to get a MIDI signal out of my 003?
2GB DDR2-SDRAM
Old 07-24-2008, 09:40 AM
Premo Premo is offline
Default
I would personally setup a stereo instrument track, insert Xpand or some Virtual Instrument and then choose a transient sound. Then do:
Pro Tools Menus>Setup>Click/Countoff... 'Output' to a desired VI. (You'll now see Xpand or any VI's that are inserted on tracks show up here.)
Or you could go out a physical midi port in Pro Tools with a midi cable, choose the port for the midi note to go out in click window and then it'll hit your hardware unit and you'll need an analog audio cable coming back into an aux track in Pro Tools to hear it. and you'll probably have some latency to consider doing it this way.
Old 07-24-2008, 01:39 PM
Default
Your first solution worked, thanks.
But re the following "choose the port for the midi note to go out in click window", this seems to be the issue I was having... can you please expand on this? What click window? The one when you click on the"C" ? It has click, bypass, factory default, etc - no port.
2GB DDR2-SDRAM
Old 08-09-2008, 11:02 PM
Default
By click window I mean the "click countoff options window" search the Pro Tools reference guide PDF and you'll find a wealth of info about this. You can double click the metronome on the Pro Tools transport.
if you don't see the metronome on your PT transport then click "View" menu at top of Pro Tools, then "transport" and add a check mark for midi controls. Now your showing wait for note, tempo ruler on/off, midi merge, count off, metronome all the missing good stuff.
Old 02-12-2015, 09:12 AM
omenman's Avatar
omenman omenman is offline
Default Re: How to change click track sound?
filosofem
Old 02-12-2015, 09:15 AM
omenman's Avatar
filosofem
Old 02-12-2015, 09:16 AM
omenman's Avatar
I have tried this but I am getting a piano note constantly
Old 02-12-2015, 09:38 AM
mesaone mesaone is offline
You can change the click sound without any workarounds or external VIs. Personally, I like Wood Block. http://www.pro-tools-expert.com/home...ck-tracks.html
Awhile back I also explained how to use your own audio files to generate click tracks.
http://duc.avid.com/showpost.php?p=2159682&postcount=20
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
change pitch of click track doesthisexist Pro Tools 10 2 01-30-2014 02:52 AM
Change CLICK sound teacherman Pro Tools TDM Systems (Mac) 3 03-01-2007 08:59 AM
Can I change the click track time signature? AbjectEvolution Pro Tools M-Powered (Win) 3 12-22-2006 01:15 AM
PT 6.4 change click sound eastcote Pro Tools TDM Systems (Mac) 12 07-22-2004 07:57 AM
Click Track (Non MIDI) Need to change tempo? Swaphappy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-06-2003 12:21 AM
