Old 05-30-2007, 09:59 PM
protourman protourman is offline
Default linking either dynamics or plugins across channels
Just a quick question that I haven't been able to address properly with any digital console yet, but maybe its been solved with the Venue: if I want to link (or slave) a noise gate across 2 channels like you would in a situation with 2 kick mics, how do you acheive this without making the channels stereo? Does the Key function do this? How do I set it up if so? If it can be done, can it be done with plug ins as well?
Thanks for any suggestions - its driving me nuts and have really become used to having the inside kick mic trigger both gates.
Old 05-30-2007, 11:09 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: linking either dynamics or plugins across channels
This can be done using either the built-in channel gate or a plug-in that supports a sidechain (key) input. Simply select the inside kick mic channel as the key source on the outside kick channel's gate.
For the built-in gate first select the Exp/Gate section and look for the KEY SOURCE field under the E/G Sidechain section (right side of software screen).
Similarly, for a plug-in select sidechain input using the Key source pulldown at the top of the plug-ins screen, when the gate plug-in in selected. You'll need to be in console CONFIG mode in order to change the sidechain to/from the default "None" setting.
Sheldon
SC48 pops when linking or un linking stereo channels lorenaguey VENUE Live Sound Systems 7 07-16-2013 08:11 AM
Issues linking/unlinking multi-mono plugins The Dougfather macOS 0 11-14-2011 05:01 PM
EQ and Dynamics Plugins don't work septic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-27-2008 08:51 AM
Stereo linking mono plugins? Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2008 07:45 AM
Expander Gate/Dynamics III vs Drawmer Dynamics DaveSB Pro Tools TDM Systems (Mac) 14 01-31-2007 05:26 AM
