Old 12-05-2020, 08:04 AM
Rodrigo Herrera Rodrigo Herrera is offline
Default Exporting Tempo Map from PT to Logic
Working with a drummer that needs the tempo map, as a midi, and he works in Logic. I'm on ProTools 12. Any advice would be appreciated
Rodrigo
Old 12-05-2020, 02:07 PM
Default Re: Exporting Tempo Map from PT to Logic
Shooting from the hip, if you create a midi track and pencil notes on every beat(do a measure, then copy/paste, or Alt-R for repeat) and export that as a midi file. When it gets imported into Logic, that should give him the tempo map. If you do this, I would make beat 1 have a velocity of 127 and for beats 2,3,4 I would set velocity to maybe 85. That way, no matter what VI is used to create the audible click, downbeats will be obvious.
Alternately, print your PT click track as an audio file and give that to the drummer. I'm sure that Logic has a way to match the session tempo to an audio click(or record the click in Logic and export that into your PT session).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 12-06-2020, 12:35 AM
Richard901 Richard901 is offline
Rodrigo
Does your PT session have audio tracks, tempo changes, but no MIDI tracks?
The quickest way I know is:
PRO TOOLS
1. Create a MIDI track - it does not need an instrument.
2. Enter one note at the start of the MIDI track. Only one note is necessary - without a note, File/Export/MIDI is greyed out.
3. File/Export/MIDI.
LOGIC PRO - One of two choices
A. File/ Open the MIDI file to create a new Logic project.
B. File/Import/MIDI File into an existing project. Choose "Import Tempo" when prompted.
Then delete the one note MIDI track.
***** EDIT *****
I've found that it's sometimes better to enter the one MIDI note at the end of the song. This will help Logic Pro zoom horizontally to show all the tempo changes.
Pro Tools 2021.3.1
Big Sur 11.3.1
Old 12-09-2020, 06:14 AM
DetroitT's Avatar
DetroitT DetroitT is offline
This may help.
https://m.youtube.com/watch?feature=...&v=uUjuN4lWJ_U
Old 12-29-2020, 05:10 PM
Thank you! I'll give that a try.
Rodrigo
Exporting sections of a tempo map crazy_ow Pro Tools 9 3 12-26-2011 08:48 AM
Exporting MIDI file without tempo map? freeBase MIDI 1 12-07-2010 10:34 PM
Exporting Tempo Changes From Pro Tools weezerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-02-2010 12:00 PM
Exporting Tempo information from LE? chiefofstaff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2010 09:30 AM
Does Exporting Midi retain Tempo Changes? teacherman MIDI 0 12-17-2008 02:45 PM
