Real-time vs OFFline bounce - LFE shifted?
Hey folks,
I am battling an oddity here - trying to collect stems for a project I am taking over, and the exported stems I got don't null with the fullmix. I *think* it is an offline bounce vs realtime issue, the weird thing - it's the LFE that is offset between the two (small things like reverb etc. left aside). Roughly 1/5ish shift. Realtime is late compared. Anybody ever experienced this? Might be a plugin in the chain... will try realtime exporting once I visit that facility again... |
Re: Real-time vs OFFline bounce - LFE shifted?
I have found that if you are using any version of Pro Tools with the Hybrid engine, that the sub bus with the greatest delay compensation won't phase cancel against the printed stems.
Randall
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
One more thing...
After the Hyrbid engine, Pro Tools has become very particular about the output that you are sending things down. I am doing some phase cancellation tests right now, for some stems that I bounced out. Even though everything is going out my 'Hardware 1-8' feed, if one of the stems is going out a sub bus of that feed (Hardware 1 - 8 (1-6)) the surrounds won't cancel. Same with tracks that I converted from 5.0 to 5.1. The outputs on the converted tracks were still going out the Hardware 1 - 8 (5.0)) out, but the surrounds wouldn't phase cancel out until I switched the output. Randall Quote:
Is it a real offline bounce? | bsomrec | macOS | 16 | 09-22-2015 03:05 AM |
Offline Bounce WAAAAAAY off time | scott llamas | Pro Tools 11 | 12 | 12-22-2014 04:28 PM |
bounce - real time only? | apfoll | Pro Tools 9 | 24 | 12-07-2012 11:31 AM |
Real-Time Bounce to Disk...REAL PAIN | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 201 | 07-26-2010 08:12 AM |
Getting Around the Real Time Bounce? | bloodspoint | Tips & Tricks | 6 | 01-02-2003 10:19 AM |
