Go Back   Avid Pro Audio Community > Dev > Pro Tools Scripting SDK Toolkit
Old 01-27-2023, 12:27 PM
JamieHardt JamieHardt is offline
Default Some Bugs
Command
SetSessionLength
Observed Behavior
When trying to set a session length less than "06:00:00:00", Pro Tools
returns an Response with an response_error_json with a
command_error value of "PT_InvalidParameter", a string. An error
by this name does not exist in the CommandErrorType
enumeration, and it is a string, and not an integer as required by the
proto.
Expected Behavior
Pro Tools should return a response_error_json with a numeric
command_error whose value exists in the
CommandErrorType enumeration.
Command
SetSessionBitDepth
SetSessionAudioFormat
SetSessionLength
SetSessionAudioPullRateSetting
SetSessionVideoPullRateSetting
Observed Behavior
Using these commands does not change the settings in the session setup
window. The session must be saved, closed and reopened before the changes
are visible in Setup.
Expected Behavior
The Session setup window should change its visible settings immediately.
Command
PasteSpecial
Observed Behvaior
When PasteSpecial is used with the `To_Current_Automation_Type`, nothing
happens.
Expected Behavior
When used in this way, this command should do a Paste to Current.
Command
CreateSession
Observed Behavior
When this command is used with the path and name of an existing session,
it will overwrite the existing file on disk without reporting an error.
Expected Behavior
This command should fail with an error if the path and name of a session
that exists on disk are given. A session exitsing on disk should never be
overwritten.
Command
GetTrackList
Observed Behavior
When there are no tracks in the session, the track_list value in the
response contains an empty JSON set object `{}` and not an empty JSON list
`[]`. This is not the correct type for this variable.
Expected Behavior
Pro Tools should return an empty list value for this value.
___
Jamie Hardt MPSE
Pro Tools Ultimate 2022.12.0
Mac OS X 12.6.2
Mac Pro (Late 2013)
Old 02-06-2023, 01:25 PM
rmajors's Avatar
rmajors rmajors is offline
Default Re: Some Bugs
Thanks for reporting these. We have been able to reproduce each of them here, and we are now tracking them with the following bug numbers:
PT-298374 Set commands don't change values in UI
PT-298375 PasteSpecial works only with the Repeat to Fill Selection option
PT-298376 GetTrackList returns and empty {} instead of [] when there are no tracks in the session
PT-298422 CreateSession deletes existing session file
The first SetSessionLength issue you mentioned has already been addressed and you should see the fix in the next Pro Tools release.
Rob Majors
Avid Software Engineering
Last edited by rmajors; 02-06-2023 at 01:27 PM. Reason: Update information related to the first SetSessionLength bug report
Old 02-07-2023, 02:27 AM
Pete Gates Pete Gates is offline
Hey Rob,
Can I ask for clarification on something? You said about a fix in the next Pro Tools release. Is that for the PTSL lib in Pro Tools or the SDK or both? If it's in the PTSL lib, does that mean that people who are running the current Pro Tools release won't be able to benefit from future bug fixes if it's tied into a library within Pro Tools, and the same with progressive Pro Tools releases and bug fixes?
Thanks,
Pete
Old 02-07-2023, 06:19 AM
alvin28 alvin28 is offline
Default Re: Some More Bugs?
Command
OpenSession
'Save Changes?' dialogue box appears.
Additional commands before this is dismissed causes Pro Tools to crash. closeSessionRequest.savePreviousOnClose would solve?
Command Request:
setOnline - Puts Pro Tools online so that playback and recording is triggered by an external timecode source.
Old 02-13-2023, 11:28 AM
rmajors's Avatar
Originally Posted by Pete Gates View Post
Hey Rob,
In most cases a fix or improvement for the Pro Tools Scripting SDK will require a change on the Pro Tools side. If a change is required on the Pro Tools side then access to the updated version of Pro Tools will be required. We don't have any plans to deploy or version the PTSL binary separately from Pro Tools. In general, you can consider the Pro Tools Scripting SDK support in Pro Tools to be treated the same as other Pro Tools application features.
The Pro Tools Scripting SDK does include versioning information in its messages and responses, as well as a way to query the host version, so client apps will be able to use that information e.g. to work around known issues when interacting with an older version of Pro Tools that did not yet include a fix.
Rob Majors
Old 02-13-2023, 11:43 AM
Farid M's Avatar
Farid M Farid M is offline
Originally Posted by alvin28 View Post
Command
OpenSession
Hello Alvin, Farid here, could you please provide some additional details on this bug? I didn't manage to get a repro, based on your initial description. What commands you were passing with the SaveChanges dialogue box opened?
Old 02-13-2023, 11:02 PM
Thanks Rob,
That was the general assumption I think, just wanted it confirmed.
Cheers,
Pete
Old 02-14-2023, 08:33 AM
Hi Farid,
Thanks for your reply.
I would assume most workflows would precursor an openSession with a closeSession command, but wanted to highlight that an openSession with session loaded would bring up ‘save changes’ box.
Follow this with a closeSession, then dismiss dialogue will crash Pro Tools every time.
Hope this helps..
Old 02-27-2023, 07:50 AM
Farid M's Avatar
Thanks, Alvin, we've been able to get a repro on your report and logged a bug under PT-299188 number. Thanks for bringing this up!
Old 03-27-2023, 03:59 PM
rmajors's Avatar
The crash when dismissing the "Save Changes" dialog after executing a PTSL closeSession request is fixed in Pro Tools 2023.3.
Rob Majors
More Bugs with AIR VIs DonaldM Virtual Instruments 5 10-26-2017 07:42 AM
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
Bugs in my box - no, REAL BUGS !!!!!!!!! Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2006 06:33 PM
known? bugs Jim 'Alien' Credland Pro Tools TDM Systems (Mac) 5 02-20-2004 12:45 PM
Bugs in PT 6.2.2 and PT w/ G5 Stage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2003 09:54 PM
