Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 11-23-2022, 05:02 AM
Syncbox Post Syncbox Post is offline
Default EQ turns off Left, Right and Centre Channel on Dadman
When I turn on the EQ in Dadman it turns the Left, Right and Centre channels off.
The dark blue dot turns to light blue and no signal is passed through.
Turning off the EQ reverts back to normal.
I've included a Screenshot for clarity.
Any ideas why it is doing this?
Also, adding a delay to each individual output, turns it off.
I'm running OSX 10.15.7, Dadman V5.6.5.1 and Firmware 1.1.1.5
Old 11-23-2022, 08:06 AM
Reckless Erik Reckless Erik is offline
Default Re: EQ turns off Left, Right and Centre Channel on Dadman
You appear to have multiple outputs and only one source. Do you have separate monitoring systems in your room? (2.1,5.1, atmos etc)
nickcath@internet.is
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2022.10 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 12.6.1, PT Ultimate 2022.10 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 11-23-2022, 08:15 AM
Yes thats right. This was suggested by Jeff Komar.
And works well as a a solution.
But my question is, why do the channels get muted when I apply the EQ.
Old 11-23-2022, 09:23 AM
creativecontrol's Avatar
Is the MTRX Device clock (Conf > Sync >) at a different sample rate than your Atmos source Input?
Also, it only makes sense to send that 7.1.4 Atmos source to a 7.1.4 Output set. You would never send that to multiple outputs of different widths. The better solution would be to have Sources:
Atmos Renderer Speaker Outputs - 7.1.4
5.1 Re-Render
7.1 Re-Render
2.0 Re-Render
BIN -> to Headphones
etc.
I would 100% also ensure that your Firmware and DADman versions are both current.
best,
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 11-29-2022, 05:06 AM
I am running the latest firmware and DADman software.
The MTRX device clock is the same.
Also, if I turn the EQ on when monitoring in 7.1 or 5.1 it turns off the left channel.
Why would the EQ effect the channels?
Old 11-29-2022, 06:53 AM
If you'd like to share your monitor profile I can take a closer look at it.
best,
Jeff
Jeff Komar
S6 FAQ
Old 11-29-2022, 07:07 AM
It wouldn't let me upload the file as it says it was a n invalid file type.
So here's a link to download it.
https://we.tl/t-REBEVgooBN
Old 11-29-2022, 07:09 AM
Thanks. Will take a look and report back.
Jeff
Jeff Komar
S6 FAQ
Old 11-30-2022, 07:18 AM
So - this is not the same Monitor Profile you have in the screengrab you sent. Not sure if that is relevant or not.
I'm not seeing any issues engaging EQ, Delays or Bass Management including switching Sources and Outputs. This Monitor Profile does in fact have multiple Source Inputs of varying widths in addition to multiple outputs.
Here's what I would recommend:
From whatever iteration of the monitor profile you are using...
(A) Settings > Monitor Profile > Remove Unused Groups (re-save profile)
(B) Settings > Monitor Profile > Uncheck and Recheck Enable Monitor
(C) Settings > Device List > IP > Restore Defaults, reboot.
Let me know what you find.
best,
Jeff
Jeff Komar
S6 FAQ
Old 12-02-2022, 11:05 AM
Hi Jeff,
Unfortunately, this has made no difference. The problem remains the same.
S3 Soloing causes channel pans to centre bug? Marsdy Avid S1, S3, Dock and Control App 4 01-20-2021 02:19 AM
Centre channel from Quad recordings Artis Post - Surround - Video 5 04-26-2019 12:10 AM
Problem with Centre and LFE channel SindriKara Post - Surround - Video 4 07-27-2015 05:57 PM
afl solo in centre channel? tomlowd Post - Surround - Video 1 10-11-2007 03:49 AM
afl solo in centre channel? tomlowd ICON & C|24 1 10-10-2007 07:42 AM
