Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 02-25-2022, 08:39 AM
off the wall's Avatar
off the wall off the wall is offline
Default Re: MTRX Studio with Dante Virtual Sound Card
Originally Posted by Farhoof View Post
But why drag along a MTRX on a vacation and not just a compact TB/USB audio interface with enough outputs to connect your monitors? Or do you need all that IO and (SPKR) processing? I'm curious now ;-)
Maybe you can get a thunderbolt HD native box and connect the MTRX via digilink, skip the Dante altogether. Obviously more expensive, but more versatile as well.
If I have a MTRX Studio, it's not a big deal to "drag" it along. This is what I will be "dragging" it in. LOL.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 05-18-2022, 02:14 AM
IrelandM IrelandM is offline
Nice!
Regards
Old 09-29-2022, 03:30 PM
Hud Hud is offline
Hi, did you get it working via dante for your vacation? How did you set it up?
cheers
H
Old 09-29-2022, 07:20 PM
cheers
H
I actually took the easy way out and borrowed an Apogee Duet for the month.
File Type: jpg 4FD3F5F4-9B2D-495C-AF20-49A756E3BDF8.jpg (70.4 KB, 0 views)
Old 10-13-2022, 11:31 AM
creativecontrol's Avatar
For those having issues with DVS on Silicon + Monterey, ping Audinate and mention the 512 error - which sometimes pops up when trying to instantiate the DVS service.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #16
Old 10-14-2022, 09:41 AM
c-tone c-tone is offline
Reinstalling DVS seems to fix this problem for a while.
www.clifnorrell.com
  #17
Old 10-31-2022, 02:06 PM
Hud Hud is offline
Hi Jeff + users
This thread intrigues me - is the theory that I can mix on pro tools over the ethernet network via DVS, WITHOUT having the HDNative unit connected to my Mac thunderbolt and to my MTRX Studio via digilink cable?!
Thanks
H
best,
Jeff
  #18
Old 10-31-2022, 05:56 PM
If you are asking if it is possible to use a Dante Virtual Soundcard Playback Engine in Pro Tools patched to the MTRX Studio - the answer is yes, however there are certainly issues to consider.
DVS can be configured from a 2x2 to a 64x64 virtual coreaudio device. The upside is simplicity and low cost. The down side is a significant increase in latency - due to it being a virtual device driver with a sizeable buffer. It also requires a bit more daycare than other solutions. Sample Rate can be toggled, must be toggled, to match the rate of both Pro Tools and the MTRX Clock/Sync source settings.
DVS on silicon seems to be improving - but was pretty bumpy for the initial releases. Both HDX and HDNTB will both be higher performance, lower latency solutions.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #19
Old 11-06-2022, 01:24 PM
Hud Hud is offline
Is it just my system? Installed Dante DVS. Error code CPU overload with DVS even with no audio tracks in pro tools. Upped the buffer samples to 1024 maximum, went through the checklist on this error code on avid support....no luck, Dante DVS is not working with MTRX studio. Maaan, so much promise....
H
best,
Jeff
  #20
Old 11-06-2022, 01:52 PM
LDS LDS is offline
H
Is there any chance you may have the wrong firmware loaded on your MTRX Studio? There are details about it with the recent DADman update - https://resources.avid.com/SupportFi...ease_Notes.pdf
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
MTRX Studio with Dante PciE card Goombot Pro Tools | MTRX & MTRX Studio 8 11-07-2021 12:01 PM
Dante Virtual Soundcard - MTRX Studio Setup TrentWilliams Pro Tools | MTRX & MTRX Studio 10 07-22-2021 06:52 PM
MTRX Studio and Dante Virtual Soundcard Ooptron Pro Tools | MTRX & MTRX Studio 13 07-14-2021 10:50 AM
MTRX Studio and Dante Virtual Soundcard Ooptron Pro Tools | MTRX & MTRX Studio 0 05-31-2021 02:36 AM
MTRX Studio and DANTE virtual sound card alvarodeiscar Pro Tools | MTRX & MTRX Studio 12 10-12-2020 01:57 PM
