I have a fairly basic question, and I have searched high and low, but cannot seem to find this:
How much hard disk space is required on the *system* drive (not the audio drive) for installing: PT LE 8 including all standard plug ins Virtual instruments (separately, or "Box Set" in total)? I have a black Macbook with a 140 GB drive, but with standard applications, iTunes, etc., I only currently have 40 GB available, and I'm sure some space is needed as "work space", so I wouldn't want to fill the entire 40 GB, of course. On the flip-side, I could uninstall some apps, such as iLife ones. Can anyone direct me to this basic requirement info? Thanks, Terry |
I don't have the exact number, but I know it's not 40 gigs. MAYBE 2, but not 40.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
If you D/L the installer, it is about 4gb, but that can go on an external disk.
Most of that is sounds for the VI's, which can be put on an external disk, too. (you might need to move the folders after installation, I don't remember) But beware that you are approaching the 2/3 to 3/4 full point.. HD performance falls off after that. Also, your Macbook has a slower drive to begin with, and it does get used during normal usage for virtual memory.. You would do well to free up some space if possible
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
PT 11 Hard Disk Requirements | bradch00 | Pro Tools 11 | 3 | 05-26-2013 08:12 PM |
Switching protools from system disk to external hard drive -- need basic instruction | sberg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-20-2012 04:15 PM |
Hard drive requirements | pcalster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-01-2010 01:05 PM |
Best ext. FW Hard Drive disk format for PTLE | Maarsmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-26-2005 06:08 AM |
PLEASE help me, confused about Hard Disk rpm requirements for PT LE | Sergeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 08-07-2002 01:12 AM |
