Greetings all, Given that the price of a 500G external hard drive is now about $99, is it any use to buy image/ghosting software eg true image? My rig runs nice (q6600/P5K) but I havent done any "imaging" to save the set up-yet. I plan to buy a few plugs, so now is the time to save, but where? internal, external hard drive, or does the imaging route offer some advantage?
Many thanks!!! |
This is one opinion. I absolutely swear by Acronis True Image(but I use version 9). I know version 10 had an issue with restoring from an image. I actually use it for cloning and I don't use the image feature(after getting stung with version 10). I have 3 system hard drives that are all 80-120GB that I rotate as system drives. 1 drive is the last solid working setup(XP with LE7.4), 1 drive is the newest latest setup(running XP and PT8) and the 3rd drive is loaded with Vista and PT7.4. I have decided for now that XP is my choice but I keep the Vista drive around just in case I get the urge to mess with it(maybe it will get Win 7). No matter what happens to any system drive, I can install one of the cloned backup drives and be up and running in 5 minutes(plenty long enough if you have a client looking over your shoulder). Since I built a duplicate computer, I cloned my system drive and installed that clone in the spare computer which now boots and runs exactly the same as my main computer with everything loaded and authorized(yes, I like to have a backup plan and a backup backup plan). There are other drive cloning software choices that likely work as good. If you are a commercial studio, I would absolutely have a cloned spare system drive. If you are a home/private user, then restoring from an image is fine (it just takes longer).
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Probably rather pedestrian, But I simply run a Ghost clone at the end of every week onto alternating backup drives. It has proven to be a worthy habit.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2022 HDX Hybrid HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
![]() Quote:
Need a file from a backup yesterday or several months back, or an image from any particular date, it's instantly available over the local net. To install an image on to a new drive (from any machine that use its services) just boot on the WHS recover disk and tell it which system and image. It rebuilds the new drive and you can boot right into it. Pretty slick system overall. --Bill
Asus P6T DLX, Intel i7-920 OC'd to 3.2GHz, 6GB DDR3-1600 (triple), Win XP Pro SP3, PTLE 8cs2, MPTK2, Black Lion 003R, UAD-2 Duo, UA 2192 Monitoring: 24-bit dig to Avocet Crane Song controller, Pass Labs x250.5 amp, B&K N801 monitors, Transparent Audio analog cabling |
There is a difference between backing up files(using Server), backing up with a drive image(saves everything including your OS and configuration, but takes an hour to restore from the image) and cloning the drive, which gives you everything and every file back in the time it takes to swap a hard drive. All are valid so pick the one that works best for you(using Server to backup sessions makes a ton of sense though).
albee
Acronis True Image Home 2009 here. Had it since v9.0. I too had a few issues with restoring images, but only from Windows, never using the Rescue CD and booting from that. v2009 seems to be solid restoring either way. thefridge As an alternative, I prefer making an image nightly of my OS drive and my Audio drive, deleting the oldest of each, so that I always have a couple of recent images to go back to should there be any problems. Also, I make an image of my OS drive before any update or upgrade, just in case. You can also mount an image as a (virtual) drive and copy off any file you need. It's also a good idea to make an image of your OS drive with a fresh, working install of Windows so that it's easy to get back to "ground zero" rather than having to install the OS and find drivers, etc. Many ways to get to the same place. Cheers,
![]() Quote:
--Bill
External Hard Drive Disk Cache | drumzalicious | macOS | 0 | 06-09-2012 11:16 PM |
Switching protools from system disk to external hard drive -- need basic instruction | sberg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-20-2012 04:15 PM |
External dedicated external hard drive | JuanCarlos | General Discussion | 1 | 02-15-2010 04:11 PM |
OT: Hard Disk Fried During Session. Using True Image To Recover. Says No MBR Found? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-05-2009 12:50 PM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-20-2002 12:26 AM |
