Old 07-12-2007, 04:42 PM
deezlee deezlee is offline
Default Pro tools and m-audio torq won\'t open at the same time-HELP?
pro tools won't open when torq is open and torq won't open when pro tools is open.
a popup window says that protools or torq quit unexpectadly
mac g5 dual 1.8 with 2G ramosx 10.9.4
so far i tried:
-opening them in a different order
-installing 10.4.9 manually (not through the updater)
-fixing permissions (after i did that, pro tools takes like 3 tries to open - it cycles through finding the files a coupla times, then stays open) but no luck
any ideas? (i'm on a deadline for a mixtape project)
thanks in advance,
noahd
Old 07-12-2007, 05:05 PM
AfricanCaneKing AfricanCaneKing is offline
Default Re: Pro tools and m-audio torq won\'t open at the same time-H
are you using the torq xponent?
unless torq is in rewire mode, i dont think you can open it at the same time as pro-tools. this applies if you set the audio output of torq to your core audio drivers. if its set to your system speakers you should be able to open torq and PT at the same time.
if anyone else has more info that would be great. i would realy love to get the torq exponent sometime at the end of the year, but its quite new on the market so not many boards have actual user experience stories to go through
2.0GHz Intel Core 2 Duo + 2GB RAM
el-cheapo compusa generic firewire 80GB
OSx 10.4.10, PTLE 7 (latest update)
Old 07-12-2007, 10:09 PM
wow, some info!
thanks!
wow, that sucks.
so there is no way for me to record myself scratching using torq on a protools track?.
thanks for the help.
lemme know if you get any ideas about how it can be done, please.
peace,
noahd
Does pro tools work with the M Audio Torq soundcard? ThatGuyDave Pro Tools M-Powered (Win) 1 05-03-2010 08:19 AM
TORQ LE and M-ESSENTIAL. cant get TORQ to record MUKULIA DESIGN Pro Tools SE and Essential (Win) 3 02-28-2010 03:39 AM
Torq + Protools LE: Can Torq work without the turntable midi interface?? Amnesiac Virtual Instruments 2 04-27-2009 09:46 AM
Protools LE and TORQ (M-Audio) conflict... housemusicjunky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-30-2008 01:12 PM
M-Audio Torq LE Included? rdolmat Pro Tools TDM Systems (Mac) 1 12-18-2008 06:58 AM
