Old 03-11-2021, 01:14 PM
user2021 user2021 is offline
Default Eleven Mk2 ....
finally purchased Eleven Mk2 ilok license,
i have a perpetual HD license, that allows to buy an Eleven Mk2 full retail license at a very good price / deal.
but i have bi-polar mixed emotions about Eleven Mk2...
Eleven Mk2 comes free for 1 year with an Active Support Plan,
but i have perpetual license without support plan = No Eleven Mk2 unless buy an ilok license.
instead of purchasing a $999usd. support plan for 1 year,
its cheaper to buy a perpetual Eleven Mk2 license...
also its cheaper than purchasing multiple Eleven Rack units.
its a No brainer.
The things i like:
1. Its the same as the Eleven Rack Hardware with v2.0 Firmware.
2. Has separated Speaker Cabinet Emulation plugin, Awesome.
3. Eleven Mk2 has Age / Speaker wear... fader control, Awesome.
4. Mk2 license comes in bundle with Mk1 license... great backward compatibility.
The things i dont like:
1. Mk2 installer does Not have AAX32 nor AAX32-DSP = cannot be used in PT HD10.3.10
Only Eleven Mk1 can be used in PTHD10.3.10,
Mk1 its an incomplete version of the Mk2, less cabinets, less mics, etc...
similar to an Eleven Rack with older v1 Firmware.
2. Speaker cabinet emulator plugin does Not have the Age / Speaker wear Fader control of the complete Eleven Mk2 Plugin. Disappointing.
Alternatives:
Line6 POD Farm 2.5 and Helix Native does Not have TDM nor AAX-DSP.
plugin-alliance has AAX-DSP, AAX32, does Not have separated speaker cabinet emulator. V3 is multi-emulation, other plugins are 1 emulation per plugin.
Peavey Revalver Mk, unknown,
Softube Amp Room,
Positive Grid Bias Amp2 Elite.. No AAX32, No AAX-DSP.
any other?
Old 03-11-2021, 01:49 PM
Default Re: Eleven Mk2 ....
Eleven Mk II is pretty nice, the AAX-64 only thing has been well discussed on DUC before.
I'll just point out that Eleven Mk II is included in the Avid Complete Plugin Bundle and that is a pretty good deal already.
There is lots of past discussion about different guitar amp sims on DUC, you should search for that, and would turn up this recent thread: https://duc.avid.com/showthread.php?t=367781 But there are many more.
Old 05-20-2021, 08:19 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
its a No brainer.
The things i like:
Alternatives:
Softube Amp Room,
any other?
Plugin Alliance amp sims can be used as speaker only. Turn off the preamp portion (and power amp, if desired). At that point it's simply impulses, but why not just use Space for IRs?
Old 05-30-2021, 01:39 AM
FunkzzaJ FunkzzaJ is offline
any other?
klevgr stark
Old 05-30-2021, 02:05 AM
JFreak's Avatar
JFreak JFreak is online now
Take a look at your Eleven license, at least mine has Eleven mk1, Eleven mk2 and Eleven LE bundled together. If so, you could just ask Avid Support to provide you oild installers that work with PT10
Janne
HTML code is On
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven LE, Eleven Full, Eleven MK II Compared Justin1524 AAX Plug-ins 5 11-19-2015 02:47 PM
Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!! quebecguitare Eleven Rack 1 09-01-2015 11:40 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
