Old 12-01-2010, 11:46 AM
lowthert lowthert is offline
Default PT9 / MBox 3 Pro
OK - wild with excitement....I got my new MBox3 Pro...to the UK from the US!!!
I had upgraded from 8.0.4 to 9 - and plugged in ready to go.....and be amazed....
It runs and I get the 'cannot locate the hardware, make sure it is turned on and press ok'....
It is turned on. It is wired up right...
A totally Avid system. It worked perfectly with MP 8 and Fast Track Ultra...
Please help before I slit my wrists...
Thanks guys.
Tony.
ProTools 2020 / OS High Sierra / UA Apollo Twin Duo / Furman AC210AE / Samsung Evo 860 NVMe / Thunderbolt SSD Audio / i7 3.4Ghz / 32G Crucial DDR3
Old 12-01-2010, 11:53 AM
Meads Meads is offline
Default Re: PT9 / MBox 3 Pro
Did you install the appropriate drivers?
Does windows see it?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 12-01-2010, 11:59 AM
Default
Well the Mbox guide tells me just to plug in and go. The drivers are all in 9 upgrade...?
Old 12-01-2010, 12:02 PM
I think you have to install the driver.
Please try the one supplied here:
http://avid.custkb.com/avid/app/self...ice&NewLang=en
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 12-01-2010, 12:13 PM
Thanks Meads ....I did try this. But the newer driver won't install. It keeps telling me that Volume D needs more 886k more space - please delete some files....
I don't have a volume D!! I have three drives - Program, Samples and Audio.
What if I totally reinstall PT9 again. Would I have to reinstall all of my third party plugs or would they go back to where they are supposed to go once the new install is done??
Appreciate your help....
Thx
Old 12-01-2010, 12:22 PM
As far as I know, since PT9 the drivers are not installed with the program anymore. You have to do it seperately (just stressing it).
Nevertheless quite strange, your experience.
If you keep your plugins folder and copy it to its desired location after you did a reinstall the plugins should still be working.
Godspeed!
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 12-01-2010, 01:05 PM
Default
So Avid. Are the MBox3 pro drivers installed with PT9? Or do I have to reinstall LE8 and the drivers that come with it - and then upgrade again to 9??
Why isn't anything just 'easy' with PT?
Old 12-01-2010, 01:08 PM
Dism Dism is offline
It's pretty easy if you follow the installation guide...
PT9 does not come with drivers.
You do not need to install PT8 to install PT9. In fact, you're much better off installing PT9 fresh.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-01-2010, 01:10 PM
Why PT8? Just install PT9 and the drivers from the link I posted earlier. Then you're cooking.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 12-01-2010, 03:56 PM
wuzlow wuzlow is offline
Thanks guys.
Tony.
The best thing to do, is uninstall Pro Tools 9 and then download the mbox 3 pro drivers from the link http://avid.custkb.com/avid/app/self...ice&NewLang=en and then re-install Pro Tools. The Drivers are not included with Pro Tools 9. I installed the mbox drivers on my laptop (even though I havent recieved the mbox yet) and I can access the mbox software control panel. Hope this helps!
Just out of curiosity, did the mbox pro come with the new Ilok?
Tom
Dell XPS 420 Desktop
Intel Core2 Quad Q6600 @ 2.40Ghz - 3 Gigs of RAM
Windows 7 Ultimate 64bit
Dell Vostro 3700 Laptop
Core i5 M 520 @ 2.40Ghz - 4 Gigs of RAM
Windows 7 Ultimate 32Bit
Pro Tools 9
003 Factory
[IMG] code is Off
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 04:24 PM
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: Haezel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2011 02:58 AM
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-17-2008 01:03 PM
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? marcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2006 08:18 PM
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds brownmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 03:22 PM
