Old 06-01-2010, 01:51 PM
wuzlow wuzlow is offline
Default DigiTechSupt, Firewire cables
Hi, I was wondering if there are any other approved firewire cables that are approved for the use of a 003 that are shorter than 12 ft. I'm trying to get a mobile rig going, but looking at only having maybe a 3 to 6 foot cable tops. Also is there any that are approved in that length for a 6pin to 6pin cable as well as a 6pin to 4pin cabe?
Will any firewire cable work? Thanks for any help you can provide!
Tom
Tom
Dell XPS 420 Desktop
Intel Core2 Quad Q6600 @ 2.40Ghz - 3 Gigs of RAM
Windows 7 Ultimate 64bit
Dell Vostro 3700 Laptop
Core i5 M 520 @ 2.40Ghz - 4 Gigs of RAM
Windows 7 Ultimate 32Bit
Pro Tools 9
003 Factory
Old 06-01-2010, 03:27 PM
binty binty is offline
Default Re: DigiTechSupt, Firewire cables
http://www.sweetwater.com/store/detail/FIW-46-106/
Old 06-01-2010, 08:24 PM
cwsand's Avatar
cwsand cwsand is offline
Tom
It should, just remember the old adage "you get what you pay for".
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2021.6
Old 06-01-2010, 09:07 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
http://www.granitedigital.com/firewi...ticcables.aspx
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 06-02-2010, 08:58 AM
hookiefree hookiefree is offline
Not to hijack or anything but if you wouldn't mind, where is the Digi approved hardware list? I need a new computer and all I can find is the compatible OS chart.
It's finally starting to come together
Old 06-02-2010, 01:45 PM
DigiTechSupt's Avatar
I think you're looking for this:
At Avid.com, go to 'Support & Services'>'Find Answers'>'Knowledgebase - Audio'.
The 'Search In' drop downs should narrow things down quite a bit. For compatibility info, select 'Pro Tools HD' in the second drop-down (Digidesign should already be selected in the top-most drop-down), leave 'All Digidesign Hardware' in the 3rd drop-down and, in the last one, select 'Compatibility'. No need to enter anything in the keyword search. Hit 'search' and you should get a list of relevant info - the top two results I got were the Mac and Windows compatibility info pages for HD.
FWIW - we don't test or approve any specific firewire cables.
Avid Audio Tech Support
Support FAQ
Old 06-02-2010, 08:41 PM
nst7 nst7 is offline
Monster firewire cables are 7 feet, and work great. They have both 6 to 6 pin and 6 to 4 pin (FW 400 only).
You can buy them online or they're usually in stock at Sam Ash stores.
Old 06-02-2010, 11:47 PM
Culhane Culhane is offline
That sounds reasonable, but I tried it for ProTolls LE on 003 rack, and got two results:
hard drives for Mac and 7.4 ASIO driver issue for Vista .....
Unless I am missing something, there is no current "official" posted hardware, such as motherboard/CPU specifications from Avid.
This does not include extensive recommendations in the user forum, which I view as the only real source available here, though they do require a certain amount of searching around it seems. Just don't want to be searching for something that is just not there.
Firewire 800-400 cables, 7.4 and Nehelem KamaSutra77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-08-2009 11:23 AM
15' firewire cables, is this ok?? SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-30-2008 04:49 PM
Anyone used the 7.5m/10m Lindy firewire cables?? Tubthumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-27-2005 04:02 PM
Anyone used the 7.5m/10m Lindy firewire cables? Tubthumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-27-2005 12:00 AM
DigiTechSupt - Question regarding DigiLink Cables Imagine Pro Tools TDM Systems (Mac) 0 07-16-2004 12:11 PM
