Compress MIDI velocity
Hey forum,
I need to pick your brains, maybe you can help. I want to compress midi velocity on a track. Is there a way to do this either as a track plugin or with an input transformer, so that I do not need to „process“ parts after recording?
SOUND! |
Re: Compress MIDI velocity
As in you want the velocity restricted to a certain range so that the level is constant?
If so, you can do that with MIDI Realtime Properties. Sent from my iPhone using Tapatalk |
Thanks.
SOUND! |
If you do the operation on a duplicate playlist, your original velocities will be preserved for future use or reference. I compress velocities by scaling them to less then 100%, then adding the amount that brings the loudest ones back to where they were.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
But MIDI Realtime Properties are non destructive.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Which is handy when you want it done to the whole track. I often perform the manual operation on phrases or sections.
MIDI Volume or Velocity Change results in part muted MIDI sound | gavriil1 | Pro Tools 10 | 2 | 07-01-2013 10:23 AM |
Can't edit velocity only anymore? Notes copying with velocity data... | kingtinker | Pro Tools 10 | 5 | 11-12-2011 10:53 AM |
Poll: Compress or not to Compress | EvilElfBoy | Pro Tools TDM Systems (Mac) | 16 | 07-08-2009 12:14 PM |
Midi Velocity | near | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-19-2004 12:13 AM |
Midi track compress | petter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-04-2002 03:27 AM |
