Old 11-03-2022, 10:00 AM
Sparky1 Sparky1 is offline
Default Locking a Specific Track's Height?
Hi there.
Is it possible to lock the height of specific tracks?
Using PT Studio 2022.10.0 on Mojave
Thanks,
Sparky
Old 11-03-2022, 05:15 PM
Sardi Sardi is offline
Default Re: Locking a Specific Track's Height?
As in the height view? Not that I’m aware of.
But, each track can be a different height, so unless your accidentally triggering a shortcut to change the height of all tracks, there’s probably no real need to lock it.
Old 11-04-2022, 03:07 AM
Ben Jenssen's Avatar
Not possible. You can opt-click a trackname to select all tracks, cmd-click tracks to deselect them, and change height of the selected tracks while holding opt-shift - none of the deselected tracks will change height.
Old 11-04-2022, 03:38 AM
danyg danyg is offline
yes, kind of... I do it with memory locations and window configuration
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 11-04-2022, 06:38 AM
its2loud its2loud is offline
There’s also Zoom Toggle
Old 11-04-2022, 06:41 AM
DetroitT's Avatar
DetroitT DetroitT is offline
+1 for window configs.
Usually short term for A/B editing (Melodyne or not)
Long term for window arrangements.
Old 11-04-2022, 07:16 PM
This is an interesting idea…🤔
Sparky
Old 11-04-2022, 07:25 PM
The reason I’d like to lock individual tracks is while mixing - I often decide certain tracks make the whole song too busy or the track just doesn’t work…
I’ve started inactivating those tracks and putting them in micro mode - but still like them to be visible so I don’t completely forget about them in case I want to come back to them and/or maybe use parts of these tracks…
Often I’ll make various other tracks larger while working on them - then return them all to small. The inactive tracks will resize to the same size as all the ones I’m using - taking up real estate
Sparky…
Old 11-04-2022, 07:35 PM
If you use the correct shortcuts (like Ben pointed out) that will not happen.
I can see locking would be useful in your circumstance, but there are ways to achieve what you’re after and as mentioned, track heights unfortunately can’t be locked.
Old 11-05-2022, 08:56 AM
Just tried this - and it's absolutely perfect.
1 click, and I'm back to having all the tracks return to the various heights I had previously...
Thank you danyg for the excellent suggestion!
Sparky
is there is a shortcut to make ALL the tracks always a specific height? Zak7 macOS 8 09-11-2018 12:41 PM
track height jknourse Windows 1 07-18-2012 02:06 PM
Zoom Track Height? daslicht ProControl, Control|24, Command|8 4 02-07-2011 05:00 AM
Track size/height MEAT Pro Tools TDM Systems (Win) 12 07-25-2007 07:39 PM
Group Track Height won go away!!!! mstucker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-08-2007 02:46 PM
