Old 10-27-2022, 10:10 PM
JamesG602 JamesG602 is offline
Default Help!!! MIDI SD3 issue killing session.
Hey guys, need some help on the fly as this bug is killing me in the middle of a session.
Specs for this:
MacBook Pro M1 Pro 16gb ram
12.6
2022.10 studio
Clarett interface
Running SD3 in a small ish rock session. MIDI is all tracked for the drums. Everything was fine until SD3 just started to stop playing in random parts of the song. Tried making a new track, copying the midi into it, but it causes the same issues. Tried restarting, rebooting, importing into a new session etc. SD3 just keeps randomly dropping out. Tried different buffer settings, different interfaces. I can’t seem to figure it out!
Please help as I need to get this back up to finish this session!
Much appreciated.
Mac Studio Ultra 64Gb Ram
Protools 2021.12 Ultimate
HDX 1
HD Native
HD Omni
HD 8x8x8
HD 16x16
S1 x3
Old 10-28-2022, 12:17 AM
Ben Jenssen's Avatar
Default Re: Help!!! MIDI SD3 issue killing session.
By SD3 you mean Superior Drums 3.
Try a different drum plugin.
If you don't have one, I think Toontrack, Addictive Drums and more have trials that have a limited set of sounds, but might just work as a workaround.
Old 10-28-2022, 02:15 AM
dominicperry dominicperry is offline
I just export a stereo wav from SD3 and pull it into the session. If you've tracked the drums already then that's the easiest fix.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 10-28-2022, 10:26 AM
Seems creating a new track and new instance of SD3 and putting the midi IN SD3 "solved" the issue.
HDX 1
HD Native
HD Omni
HD 8x8x8
HD 16x16
S1 x3
MIDI in Pro Tools 11 is Killing Me AgentGFunk Pro Tools 11 1 09-21-2015 01:18 PM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Slow Sluggish Delays Beachballs----killing the session flow Zep Dude Pro Tools TDM Systems (Mac) 5 08-01-2007 07:52 AM
Digi, Your Midi IS Killing me 25ghosts Pro Tools TDM Systems (Mac) 12 12-24-2006 07:21 AM
Is my Reason file killing my PT session? timmy4402 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-26-2004 12:44 PM
