10.8, Kontakt 5 and 10.3
Anyone successfully running full Kontakt with 10.3 and 10.8? It crashes PT on launch 100% of the time if the plugin is in the folder. Hope they'll release an AAX plugin soon, but until then, am stupefied why it's crashing.
It's also noted on the NI forum, but no response from NI yet. |
Re: 10.8, Kontakt 5 and 10.3
Quit out of Protools, Launch K5 stand alone and load ONE patch from the factory Library Now launch Protools and load up Kontakt As for now, you will need to push this workaround a couple of times a day, probably as am I... But it works here like this, 100% of the time Best of Luck
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
Odd. I am not having any issues with K5.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
Thanks for the tip, but no go. Still crashes on launch. Stand alone works fine. Deleted Kontakt prefs a bunch. In 10.8 I could get it to launch by deleting the prefs, and launching Kontakt, and making sure memory server was unchecked. It would crash on startup in PT if memory server was on.
But now, no matter how many times I delete the Kontakt prefs and make sure memory server is off, 100% of the time if the Kontakt plug is in the plugins folder, it crashes ProTools on launch. This started with 10.8.1 by the way. Such a drag. Others are noticing it on NI forum. Weird. Just have to hope for an NI fix I guess, but hard to live without Kontakt |
Yep, tried several times, crashes still 100% of the time doing exactly as you did. Bummer.
+1
Music is the Message |
Dave Marsden UK |
Total fail on this end. Mountain Lion, PT 10.3HD & Kontakt 5.03 causes PT to crash when starting up. If I remove Kontakt from the plugins folder all is okay. At the moment I'm using bidule rewire as the host for Kontakt.
Got a response from NI & they acknowledge there is an issue. |
2) In the stand alone toggle enable memory server. 3) Quit Protools and Start Standalone and load ONE patch from K5's factory library. Keep it open 4) Launch Protools I have been having those problems since Mountain Lion but above workflow does it for me... Give it a few goes... You should be ok... Hope this helps - Good Luck
PT presets from kontakt 4 not opening in kontakt 5 | table17 | Virtual Instruments | 0 | 02-06-2012 12:13 PM |
OT: Kontakt 4, 8.0.1, W7... | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-11-2009 11:43 AM |
Kontakt 2 Stand Alone vs RTAS, Kontakt vs Giga | ryan de topanga | Pro Tools TDM Systems (Mac) | 18 | 05-17-2005 06:36 AM |
Anyone using Kontakt with LE? | mannikin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-29-2005 09:38 PM |
