![]() I have a brand new iMac, out of the box just last night. I installed 7.1, and it works, no bugs I don't think. However, I tried to bounce a session I already had containing 8 tracks of Audio, 1 auxilary reverb send, and a master fader. The only plug-ins on the whole session are one stereo d-verb plug-in, the digi-rack compressor and 4-band EQ. The playback engine shows the H/W Buffer Size to be 1024 Samples, 2 RTAS Processors, and 85% CPU usage limit. All the same, at the end of the 5:30 bounce, I still got a CPU error! The same annoying one I used to get when I ran too many plugins and the same one that suggests deleting tracks or increasing the H/W Buffer size! What do I have set up wrong?? I don't think this is supposed to be happening... Why am I running out of CPU power?? Any ideas?? |
Is it an Intel iMac? How much RAM is installed? Did you install ProTools LE 7.1.1 ?
Quad 2.5 G5, 4.5G RAM |
yes, it's an intel iMac, 512MB of RAM and ProTools 7.1
Are you using the same harddrive for both the program and the audio files?
//Kenneth "Knek" Nordenmark |
![]() You should have a minimum of 1 gig RAM, prefered 2 gig. The Pro Tools version has to be the "intel version 7.1.1" Separate drive for your audio sessions |
Sounds like he's running 7.1 under Rosetta? Remarkable if it even works, especially with 512M RAM.
On an Intel Mac, you need to install the 7.1.1 update.
Pro Tools 9 and iMac Intel duo 2.8 | sean shannon | Pro Tools 9 | 4 | 02-20-2011 01:56 PM |
Dual 2 GHz G5 Power PC vs. 2.66 GHz iMac Intel Core 2 Duo | dminor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-20-2009 12:06 PM |
intel imac usb does not power mbox2 on start up PTLE7.4 | 1968bob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-01-2008 01:19 PM |
intel duo core iMac + pro tools 7.11 not launching | BigBoy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-14-2006 08:27 PM |
Pro Tools M-Powered/iMac Intel Core 2 Duo | kitchen | Pro Tools M-Powered (Mac) | 0 | 10-02-2006 09:42 AM |
