Hey
This might not be worth anything.. But I just wanted to let you know that I switched to mac from pc last month.. And while waiting for the osx intel update of PT I installed BootCamp and then XP and run it in windows at the moment. Might sound like a stupid idea, but it solved my not-being-able-to-record-problem right now. I don't know if it has been posted here before, I just wanted to mention that it works.. pretty neat actually.. Does anyone else have it set up like this? Would be nice to hear what others have to say about it.. I have some weird problems evey now and then, like it says the buffer is too small.. but 99% of the problem is solved just by changing a setting and then changing it back, and then it works like a charm.. so far at least.. |
Thanks for your post on this topic. I'm about make the plunge and buy
an Intel Mac and untill PT is ready for Mac Intel OS, I'm going to continue using PT for XP using this setup.
2006 'Blackbook' Core Duo 2.0 ghz. 2 gig OWC RAM 10.5.8 PT Mpowered 8.04, Logic 9.1.1 Waves SSL,Omnisphere,Korg Legacy Digital Absynth 4, EZ Drummer Project Mix I/O w/ Black Lion Mod Axiom 61,25, Korg Nano Pad |
i just posted in another thread that i also have pretty huge midi problems.. i'm looking into it to see if it can be resolved.. but so far, midi is unusable..
i also keep most of my posts to the xp part of the forum.. |
i just found out that midi works almost as it should if the edit window is closed durig playback.. i also updated my interlok drivers, and it almost worked as it should with the edit window open then..
before this, i also followed the troubleshooting faq for xp.. not minding the bios section.. |
You don't have to buy any special cds.. I have no idea how microsoft handles your serial if you install on different machines, but i'm sure it will work..
BUT, the install cd MUST contain service pack 2. i don't actually know why, but apple states this on several places. other than that, xp will just believe that the computer is like any other pc.. just be sure to follow the instructions when you install bootcamp, and you'll probably be fine. |
Anyone Running PT 10.3.X on an iMac Intel Core Duo | Torchlight | Pro Tools 10 | 12 | 04-29-2013 10:51 PM |
intel imac usb does not power mbox2 on start up PTLE7.4 | 1968bob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-01-2008 01:19 PM |
RUNNING XP ON INTEL IMAC | hang tuah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-19-2006 06:19 AM |
PT LE 7.x on iNtel iMac running Windows XP | KingFish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-23-2006 09:23 PM |
XP on a iMac Intel G5 running PTLE 7.1 | Darneo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-23-2006 04:58 AM |
