C|24 - Headphone Mix - Cue Outputs
I am currently running Pro Tools 9 HD on a Mac Pro, and using a C|24 and HDI/O. I know how to create a headphone mix by sending it out of the Cue Outputs (Stereo Signal). I have this output running to a Rane HC 6s Heaphone Console. The HC has 6 inputs and outputs. Is it possible to make multiple headphone mixes (ie. one for guitar, one for drums, one for vocals, etc.) and send them out of the cue outputs and into each individual headphone input? I have been searching and I am only able to send a stereo signal from the cue outputs.
Again, I am able to get one mix into the headphone console, but I would like to be able to send multiple independent mixes to so that the artists can hear a personal mix in their headphones at the same time. Thanks for the help! |
Re: C|24 - Headphone Mix - Cue Outputs
You can send as many mixes as you have outputs on your interface!
If you have an 8 output interface you could have 3 stereo mixes for cans, or 6 mono for that matter. Just set up your headphone mixes in PT, buss them to a Aux track and send that to your interfaces outputs.
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
The easiest way to get multiple outputs is to ignore the cue output of the C24 and use your interface directly to your headphone mixer. The only issue is you will lose on board talkback from the C24 to your headphone sends.
www.ShadowSound.co.uk PT8 HD 2, Apple G5 1.8GHz dual core,96 i/o, 888 i/o, 96i i/o, Control 24 |
But you can route a cue output from your C24 directly into an input on the headphone mixer, and you will still have talk-back into the headphones. You just have to be willing to use one of the 6 inputs for the talk back mic. Or you could send an instrument/track along with your talk back mic from a cue output into an input on the Rane.
Flying Rock Studios |
Thanks for the help. If I understand this correctly, in order to get multiple mixes, I can't simply use the cue outputs, I have to use the interface outputs or main outputs to route to the headphone console. I know that I can setup an external talkback mic, and I can route that to the various outputs. Is it possible to route the onboard talkback mic to any output other than the cue outputs?
Mac Pro - OS 10.7.4 Pro Tools 9 HD C|24 - HD I/O |
On the Cue Outputs DB25 connector is a Talkback Slate Output.
Either bring that into you patch bay or connect to directly to an input on your interface
Digi 002 static/distortion from Monitor Outputs and Headphone jack | CyberTribal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-22-2013 07:31 PM |
Mbox3 outputs to an external Headphone Amp? | woodrow886 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-26-2012 02:05 PM |
outputs/headphone mix | antwellington1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-20-2007 01:59 PM |
Mbox Headphone outputs intermittent | nomad1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-25-2005 04:18 PM |
Adat bridge for headphone mix outputs | Cecil Sweet | Pro Tools TDM Systems (Mac) | 2 | 09-10-2002 12:40 AM |
