Old 06-19-2022, 11:37 AM
basslik's Avatar
basslik basslik is offline
Default High Sierra 2021 ?
Has anyone successfully able to install 2021.3 on High Sierra ?
Thank you for your time and Happy Father's Day too all.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 06-19-2022, 12:03 PM
BScout BScout is offline
Default Re: High Sierra 2021 ?
Yes. Works. As does 2022.5
Old 06-19-2022, 12:11 PM
basslik's Avatar
Thanks Bscout.
Is there a process ?
Or simply disable SIP.
Old 06-19-2022, 12:50 PM
You don't have to disable anything. Just run the installer.
Old 06-19-2022, 12:55 PM
basslik's Avatar
Thanks Bscout.
I went off of the capability chart and shows High Sierra 2020.12 the latest version for High Sierra.
I have PT 2021.3
Will give it a whirl, thank you.
Old 06-19-2022, 02:49 PM
The compatibility chart is what Avid tests against. Doesn't mean it won't run on others (and the installers don't check what macOS it is trying to install on.)
Avid typically only tests on 5 versions of macOS so when it adds a new macOS version to their test setup, they stop testing on the oldest versions.
But I've ran all of these with zero problems. (I've actually probably had less problems than users on the latest "compatible" macOS)
Old 06-21-2022, 11:20 AM
basslik's Avatar
Yeah I remember those days where you had to go to YouTube and find a workaround. Thank you very much. ( GREATLY APPRECIATE IT )
Old 06-21-2022, 03:47 PM
sdelsolray sdelsolray is offline
I've run the following recent Pro Tools versions on a 2011 iMac 4 Core 2.5 GHz i5 under High Sierra v 10.13.6:
PT Standard 2020.12
PT Standard 2021.12
PT Studio 2022.4
PT Studio 2022.5
No issues.
Old 06-22-2022, 02:47 PM
Been running PT 2021.6 on OSX 10.13.6 on the 2012 cheesegrater in my profile and it's been just fine. Good to see that the latest versions seem to be running okay.
Jack
QAPLA!
2021.6 and High Sierra subwoof Pro Tools 28 02-26-2024 03:49 PM
2021.6 with High Sierra 10.13.6 subwoof Post - Surround - Video 6 12-13-2021 07:23 PM
Upgrading to PT 2021.10 on macOS 10.13.6 (Hi Sierra) stargazer Pro Tools HDX & HD Native Systems (Mac) 4 11-17-2021 01:50 PM
Pro Tools 2021 supported on High Sierra? innerbooty Pro Tools 6 04-14-2021 04:03 PM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
