Battery 3 problem with PT 8
We have 2 machines at work one is HD dual proc NOT an intel proc and battery works fine on the pt 7 boot but on 8 it will play for about 30 sec then start skipping for 10 sec like a CD skip then stop. PT 8 is pretty much unusable on this machine. On our other machine its M-powered and a quad intel proc and it seems to work a little better but drums will stop triggering for a few sec at a time in random places but no skipping. Anyone have a solution for this i find it hard to believe digi and native instruments have not addressed this problem. Thanks!!!
Re: Battery 3 problem with PT 8
REALLY? you mean to say that you are having problems with
PT8 and native instruments VI's shocking!!!
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
There are issues with PT and NI. have you tried reducing your rtas processors by one? they need to be set to an odd amount!! 1/3/5/7 this helps the rtas playback stability. Chris
I'm on a PPC DP 2.7 Pt's8cs2 OS 10.5.7.
Battery 3 only became usable after I install the Kontakt Beta 3.5 (Need Kontakt 3) What ever they changed (New Sample engine) for Kontakt now allows Battery 3 to work well in Pro Tools 8. They(NI) are sooooo Sloooow to address their products. But, there is some light. If you have K3, give it a whirl. |
Might want to check out this link from NI....
http://www.nativeinstruments.de/inde...s&tsr_id=59574 may have some info to help you....i know there is a beta 3.0.5 version of Battery 3 in the works.... hope this helps J Fred
G4 MDD Dual 1.42, 2 gig RAM, MAC OS 10.4.11, PT 7.3.1cs8, 192 I/O, Gibson Stereo 79RT |
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
Hello,
You won't have to upgrade Kontakt if you don't want as Battery is getting its own upgrade... http://www.native-instruments.com/fo...ad.php?t=53921 Cheers evs |
"Getting it's own upgrade"
NI logbook, stardate 04-09-2007: Upcoming patch: Battery 3.0.5 NI logbook, stardate 17-01-2008: Updated to reflect 3.0.4 release. NI logbook, stardate 13-02-2009: Updated to reflect upcoming 3.0.5 version. NI logbook, stardate 04-03-2009: Updated to reflect beta testing phase. |
Battery 3 Plug-In Problem | bubbiesdod | Virtual Instruments | 4 | 02-25-2008 02:48 PM |
Battery 3 Plug-In Problem | bubbiesdod | Pro Tools M-Powered (Win) | 0 | 02-25-2008 07:33 AM |
Problem With Battery 2 In PTLE7 | dadadex | Virtual Instruments | 0 | 10-14-2006 02:56 PM |
NI Battery Reinstall Problem | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-01-2003 07:57 PM |
PROBLEM - Battery and PTLE | Eric Baragar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-02-2002 03:07 PM |
