Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 05-06-2021, 07:05 AM
digiot digiot is offline
Default 2 Dongles for Ethernet!?
There has to be a more elegant way to run the Carbon of a MacBookPro!? I was hoping my Thunderbolt Display with build in Ethernet would do the trick, but no go. It doesn't seem to recognize the Carbon. So now I am running Ethernet to Thunderbolt2 to Thunderbolt3 in to my MacBookPro. Are there any Thunderbolt 3 hubs with Ethernet that would work? or how about a single Thunderbolt3 to Ethernet dongle!?
Old 05-07-2021, 07:06 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Default Re: 2 Dongles for Ethernet!?
There are a few on the AVB compatible TB3 --> Ethernet adapters on the market, but in testing we had issues with them all to some degree. The double Apple dongle, while inelegant, was the most stable.
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 05-08-2021, 09:00 AM
Yeah I figured as much.
Old 07-08-2021, 01:41 PM
darkwavo darkwavo is offline
For a newer Mac air with 2 usbC ports only :
would I need a Ethernet -> TB AND a TB-> USBC?
Thank you
Old 07-08-2021, 02:22 PM
dominicperry dominicperry is offline
Thank you
It's shown on the Carbon page.
Dongle one - USB-C/TB3 to TB2
Dongle two - TB2 to Gb Ethernet
https://avid.secure.force.com/pkb/ar...ements#adaptor
Old 07-09-2021, 01:59 AM
Thank you . Most inelegant connection though… seems dodgy
Old 07-09-2021, 02:07 AM
Agreed.
It would be nice to know what else Avid has tested, so that we don't speculate as to what might work. For example, the Caldigit TS3 Plus doesn't support AVB through its Ethernet port (similar to the monitor Ethernet ports described above) but Caldigit have recently released a USB-C/TB3 to 10Gb adapter, which does support AVB.
https://www.caldigit.com/connect-10-g/
Setting aside the generally poor reports out on the 'net of connections dropping and similar reliability issues with this new adapter (very much in contrast to the TS3 Plus, which most people think is great), has Avid tested this one, or is it too new? It might be a great option, or it might be a disaster. We don't know without trying.
Old 07-09-2021, 05:51 AM
K Roche's Avatar
K Roche K Roche is offline
Humm ? Not clear exactly what are you saying or what you mean by "no go" ,,,, do you mean you tried to connect your Thunderbolt Display directly to one of the Carbon ethernet ports ?
But if you do want to use your TB Display as a second display It should work if you connect the TB Display to your Mac and Mac to Carbon ..... I run my old Cinema Display fine connected to my iMac
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 07-10-2021, 09:23 AM
I am not using an Apple Display but a Samsung 4K Display with Thunderbolt 3.
From what I have seen is that most manufacturers of Thunderbolt 3 peripherals with Ethernet ports use the USBC protocol for Ethernet which doesn't support AVB.
I have gotten used to the double dongle lol
Old 07-10-2021, 10:32 AM
K Roche's Avatar
Sorry to be so dense but I still don't understand. The double dongle only has to do with going from Carbon to Macbook pro. But If your Macbook Pro has a second TB 3 port ?? Can't you connect the Samsung to the Mac via TB 3 and then have two displays , the Macbook and the Samsung ?
System :
Enjoy the Journey
.... Kev...
Dongles and DOD johnnyu Pro Tools 10 26 12-12-2012 04:02 PM
Dongles Shrackattack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-09-2009 06:55 AM
Dongles Dongles Everywhere Digibill Pro Tools TDM Systems (Mac) 21 02-10-2006 04:58 PM
Dongles/usb john a Pro Tools TDM Systems (Mac) 3 01-15-2002 10:07 AM
New G4 w. Dongles Charles Deenen Tips & Tricks 1 12-18-1999 03:49 PM
