Old 11-01-2017, 10:40 AM
JayRay JayRay is offline
Default "Slip Tool" in Pro Tools ?
I'm a Pro Tools user but I've just noticed there's a tool called "Slip Tool" or something like that in Cubase.
I watched one video where they were editing guitars. It's a tool that you can move the audio INSIDE the region.
You can do this actually in PT by choosing the region and then holding Control key and then nudging with + and -.
But is it possible to do with mouse? That would be so much quicker.
Please let me know if this is possible on PT10-12! Couldn't find any info on Google.
PS. Sorry for posting this to wrong area. Admin can move this to different area if wanted.
Old 11-01-2017, 12:27 PM
Ben Jenssen's Avatar
Default Re: "Slip Tool" in Pro Tools ?
Sounds to me like elastic audio - like, grab a snare hit and move it...
Old 11-01-2017, 12:31 PM
yes but it's just not that simple as in Cubase, Reaper etc
And if this feature is still not available on PT.. i wonder why it's so hard for Avid to add it.
Old 07-14-2021, 07:53 AM
everglass everglass is offline
Reviving this - looking for the answer!?
Old 07-14-2021, 10:40 AM
The Weed's Avatar
The Weed The Weed is offline
"It's a tool that you can move the audio INSIDE the region."
Yes, Pro Tools can do this, as long as there is audio outside the Clip's end or ends. There would have to be to move any audio INSIDE the Clip.
From the Shortcut Manual:
Nudge data within current Clip to left (+) or right (–) by Nudge value (keeps Clip start/end and moves underlying audio)
Mac: Control+Plus/Minus (+/–) keys
PC: Start+Plus/Minus (+/–) keys
I can't remember if there is a modifier key to allow using the Grabber Tool to slip the audio within the Clip or not.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
"Pro Tools Trying to Install Helper Tool?" anackman Pro Tools 12 8 03-23-2016 04:31 PM
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] andrew24c macOS 4 07-23-2014 07:21 PM
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Command Key : Slip or "Match Criteria"? Pieterrr macOS 5 06-04-2012 08:57 AM
Slip mode - viewing what's "underneath" a pasted region nhwinni Pro Tools 9 2 09-08-2011 07:10 PM
