distortion on inputs
Hi all,
Every few minutes or so, my inputs into pt suddenly become incredibly distorted. If I record, the files have this distortion on them. If I go into settings> playback engine and just quickly toggle on and off the "ignore errors during playback" option, the distortion goes away for a few minutes, as if it's been reset. As far as I can tell, there's no one specific situation that brings about the distortion - it just happens all the time. I'm not running any plugins. This is definitely a pt problem as I can monitor my delta inputs and there is no distortion on these even when there is in pt. I have played about with my buffer size with no success. I have also done the general trouble shooting steps. A search of the forums reveals that a few people appear to have had similar issues, but solutions to the problem don't seem to have been posted on these treads. Here's a couple of links to people I've found with similar issues...apologies if I've missed a thread which already tackles this problem. http://duc.digidesign.com/showthread.php?t=279626 http://duc.digidesign.com/showthread.php?t=231731 My Sandra report is in a post below. New here, so hope I've provided all the neccessary information. I'd be very very grateful for any help, Jonny |
Re: distortion on inputs
SiSoftware Sandra
Computer Model : Dell Precision T1500 Workgroup : WORKGROUP Host Name : jc User : Jonny Processor Model : Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Dell 0P67HD BIOS : Dell 1.0.1 09/18/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : Dell Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core Desktop (Lynnfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 8GB DIMM DDR3 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA Quadro FX 580 (32 SM4.0 1.1GHz, 512MB DDR3 2x800MHz, PCIe 2.00 x16) Video Adapter : NVIDIA Quadro FX 580 (32 SM4.0 1.1GHz, 512MB DDR3 2x800MHz, PCIe 2.00 x16) Graphics Processor Storage Devices Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (D:) Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:) Generic Flash HS-CF (USB) : N/A (G:) Generic Flash HS-COMBO (USB) : N/A (H:) TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (E:) TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices DATAPART1 (D:) : 298GB (NTFS) @ Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) RECOVERY : 750MB (NTFS) Hard Disk (C:) : 297GB (NTFS) @ Seagate ST3320418AS (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Removable Drive (G:) : N/A @ Generic Flash HS-CF (USB) Removable Drive (H:) : N/A @ Generic Flash HS-COMBO (USB) M-Powered (E:) : 7GB (CDFS) @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (F:) : N/A @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell P55 LPC Interface Controller LPC Legacy Controller 1 : Fintek F71882FG/F71883FG Audio Device : Dell P55/PM55/3400 High Definition Audio Audio Device : VIA M Audio Delta-66 Serial Port(s) : 1 Disk Controller : Dell P55/PM55/3400 6 port SATA AHCI Controller USB Controller 1 : Dell P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Dell P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Dell FW322/323 IEEE1394 OHCI FireWire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : () Media Player : () Network Services Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
What interface are you using?
m-audio delta 66, latest drivers.
Thanks for any help, Jonny |
somebody plllleeeeaaassse help! Anyone know anything about this problem?
massive distortion on guitar inputs | wav28 | Pro Tools SE and Essential (Win) | 0 | 03-05-2012 10:29 AM |
Using Eleven Rack inputs like POD X3 inputs | dayslypper | Eleven Rack | 1 | 10-09-2010 09:15 PM |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
Pops, Crackles, Distortion on VI's and Inputs | cziebold | Pro Tools M-Powered (Win) | 1 | 02-12-2009 09:37 AM |
MBOX2 MINI - Distortion on inputs? | fredmaher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-25-2006 02:39 PM |
