Surround
I realize that Carbon is not set up for surround monitoring. But it does have 8 outputs that could be sent as 7.1 to a monitor controller.
If I am using a Carbon with Ultimate software with the 8 outputs routed to my monitor controller can I still mix in surround? Or will the software be somehow be limited to stereo? Can surround channels also be sent to the Carbon DSP? For example if i wanted to use the Carbon DSP on some surround channels to free up in computer DSP. Or do only Stereo AAX DSP plug ins work on the Carbon DSP? And the next big question. When will surround monitoring be implemented? There must be demand from the music community this is aimed at to also have an interface for mixing in surround when needed. Any input on this would be appreciated. |
Re: Surround
Hello,
As long as you use Pro Tools | Ultimate you can mix in surround with Carbon. Yes, you can use DSP on surround tracks. I can't give an estimate on when support for surround monitoring control will be implemented, but it's on the list. Hope that helps.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Re: Surround
Thanks for this. It is helpful.
Re: Surround
Can someone point me to some material as to how to set this up, or explain it to me. Thanks in advance. |
Re: Surround
I have been doing more research prior to purchasing the Carbon and was wondering if I needed to add a surround monitor, like the Coleman Audio SR7.1MKII - Surround Level Control when using Pro Tools Ultimate?
I am new to Pro Tools and just setting up a system. |
Re: Surround
Yes, that's correct. Kyle
Re: Surround
Thanks Kyle. I know that in one thread you mentioned that surround sound monitoring for Carbon was coming. I am sure you cannot answer when that will happen, but can you share if it's still on the horizon?
Re: Surround
Just in case you have not seen this
http://dingdingmusic.com/-titles-/dolby-atmos-1.htm |
Re: Surround
Kyle, ive searched everywhere to find out what the word SUR stands for, located on the output strip on the Carbon. Is that what its for? Surround?
Re: Surround
We haven't announced what that's for yet, so I can't share any details.
Surround Panner for Surround Send in PT Control App | tomaspal | Avid S1, S3, Dock and Control App | 6 | 08-15-2018 07:59 PM |
Collaborating surround with non surround users/output issues | emminova | Pro Tools 2018 | 2 | 02-18-2018 09:57 AM |
Ideal surround workflow with PT9 & 002 but no surround speakers? | EricWillhelm | Post - Surround - Video | 5 | 11-16-2010 06:45 AM |
SRS Circle Surround - Matrix Surround Troubles | mrdale | Post - Surround - Video | 1 | 08-11-2006 02:12 PM |
Anyone using Waves 360 Surround and/or Dolby Surround plug? | Wheelieboy426 | Pro Tools TDM Systems (Mac) | 5 | 12-10-2002 02:13 PM |
