Old 07-30-2013, 09:30 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Minimize Additional Latency noise
No I don't think so - I would however make sure the software is up to date and qual'd for PT11
I never used that button till once and did some vocals and in the mix I heard pops and clicks that were on the actual audio track - never check it since
I don't know at this point - I assumed the easiest fix - doesn't sound like its easy
Why not leave it at 64? Or 128 I don't think most systems sound fine at that sample rate
Daniel
Old 07-30-2013, 09:45 PM
SearingSounds SearingSounds is offline
Yeah I just updated my Duet 2 firmware and software and the problem still exists.
I was just hoping I could get low latency at higher buffer settings like I can in Logic Pro with their "low latency button". I will take your advice and use the 64 and 128 settings when recording. Thanks for your help!
J
Old 07-30-2013, 09:58 PM
YYR123's Avatar
Yeah that's the best I've got - sorry hopefully someone can chime in and point u in the right direction
Daniel
Old 07-31-2013, 07:38 AM
I appreciate your help! Hopefully I will find a solution soon. I am thinking that not too many people have actually checked this "Minimize Additional Latancy" box.
Old 06-12-2021, 07:39 AM
thirstypirate thirstypirate is offline
I realize this is an ancient thread but just in case anyone else stumbles across it like I did, this is what the manual has to say:
The Host Engine options in the Playback Engine determine error reporting during playback and recording. This is especially useful when working with instrument plug-ins.
On Pro Tools|HD systems, there is a single Host Engine option. On host-based Pro Tools systems, there are two Host Engine options.
• Enable error suppression only if you are experiencing frequent errors that are interrupting your creative workflow. When error suppression is enabled, you can experience a degradation of audio quality. However, this may be
acceptable in order to avoid interrupting playback and recording when working with instrument plug-ins.
• Disable error suppression when you need to ensure the highest possible audio quality, such as for a final mix.
PT 9 - "Minimize additional I/O latency" PROBLEM elmodagansta Windows 2 04-27-2013 06:11 AM
Minimize Additional I/O latency william.bond55 Pro Tools 10 0 03-16-2012 08:44 AM
Whats the best way to minimize midi latency weezerboy MIDI 3 08-04-2008 09:44 AM
How to minimize latency ram1500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-02-2007 03:13 PM
how best to minimize latency? vyatka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-11-2000 07:48 PM
