Old 04-24-2021, 10:26 AM
briaboy briaboy is offline
Default Multiple copies of plugins - delete?
Hello,
I seem to have acquired/created multiple copies of the same plugins. Most are in Avid/Plugins as expected, but other go to folders nested within, some more than once! (see attached screenshot). Not 100% sure how this happened, but is it safe to delete the duplicates?
Thank you.
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 04-24-2021, 10:34 AM
Eric Lambert's Avatar
Default Re: Multiple copies of plugins - delete?
Can you add the screen shot? And you might get better results if you post this question in the main Pro Tools subforums.
Old 04-24-2021, 10:47 AM
sorry, here it is!
Old 04-24-2021, 01:58 PM
Its PROBABLY safe to delete, but I would not. I WOULD move duplicates to another folder(I would likely add a new folder to the desktop and call it "plugin dupes"). Then use PT for a week or so to make sure everything works correctly. After a few weeks, I would drop that folder in the trash(I always like to have a backup plan for when things go wrong). If any plugin fails to load, drag that one back into the plugins folder
One thing to keep in mind: Some that look like duplicates might actually be different versions for stereo, mono or dual mono.
Old 04-24-2021, 03:07 PM
haha! My thoughts too, thanks!
Old 06-19-2021, 08:55 AM
basslik's Avatar
basslik basslik is offline
Hey Dave I installed a free plugin but installed others to entice to buy(wrapped plugins). I have no idea how to remove the ones that are not free ?
thank you.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 06-19-2021, 09:16 AM
thank you.
Not sure I understand, but most plugins can just be removed from the Plugins folder. If that doesn't work, I would uninstall the entire package that included the freebie, then re-install just the freebie. If none of this helps, what plugins are you having trouble with?
Old 06-20-2021, 04:15 AM
Why not make use of the 'unused plugins' folder that Avid kindly provides us? That's what I do especially for something like IKMM's TRacks installer which installs every TRacks plugin when all you want is just one or two plugins.
Jack
QAPLA!
Old 06-20-2021, 10:42 AM
I do use that folder sometimes. For temporary stuff, using a separate folder is easier IF the Plugins(unused) folder has stuff in it already(a separate folder avoids any confusion on what to move back). As for TRacks and the like, if I pull those out, they are not likely to go back in Remember, the cool thing about all this is; there's 4 ways to do something. The bad thing about all this; there's 4 ways to......
Old 06-20-2021, 11:56 AM
Ben Jenssen's Avatar
I also use mac color labels on plugins, like; one color for Avid basic plugs, one for 3rd party safe and tested, and so on. Makes it easier to spot newly installed, updated and so on.
HTML code is On
Multiple copies of an OMF while copying session Unskirmisher Post - Surround - Video 2 08-07-2016 12:32 PM
Editing MIDI across multiple copies babygoboom Tips & Tricks 3 12-02-2015 06:23 AM
Multiple computers = multiple copies? Earfatigue Pro Tools 10 8 03-07-2012 05:47 PM
Using multiple copies of OS X copywell Pro Tools TDM Systems (Mac) 1 01-04-2004 01:11 PM
OMS does not allow multiple copies... c_hebb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2002 07:04 PM
