Old 05-29-2003, 03:19 PM
APinkFloydSound APinkFloydSound is offline
Default Using 2 002\'s together?
Does anyone know if it is possible to use two 002's together to get 16 tracks at once? The studio that I work at has two of them, one for a mixing room and one to record to.
Mac G4 1Ghz processor, 1G of RAM
Old 05-29-2003, 05:01 PM
BeachDog BeachDog is offline
Default Re: Using 2 002\'s together?
No it will not work. No two LE products will work together.
Old 05-29-2003, 07:50 PM
Doc Doc is offline
Not on the same computer anyway. If you have two computers, you could lock the two 002's together using S/Pdif and midi and record 16 analog ins at once. Could be a bit cumbersome though. You'd need to run two sessions together then network the files or just run the two machines to mix later.
If you have access to an adat interface, you could use the adat inputs on the 002 to add another 8 analog inputs. Much simpler but you'll need an interface. Also, you'll be limited to 48K max through adat.
Old 05-29-2003, 08:02 PM
froyo froyo is offline
Hello. Dannielle is right. Steinberg has something called VST System Link in which you connect all I/O's from one computer to another by the means of one audio cable. I know it's Steinberg, but I also thought they would never, ever support ASIO so who knows. The more people (re: manufacturers) who jump on board will make things better.
froyo
Old 05-30-2003, 03:49 AM
auxsend1 auxsend1 is offline
If you just need 16 inputs at once just get an ADAT bridge or an Octopre w/ ADAT card.
Can PT 8 run on two different 002's? Albert VS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-13-2010 08:30 AM
USING TWO 002's pav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-24-2009 09:43 PM
Two 002's together? Studio Tech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-13-2007 06:40 PM
I got one of the first 002's... Jerry J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-25-2006 08:39 AM
2 002's? edytnbch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-25-2004 08:12 PM
