i´m currently working with a 450 g4 and protools le with digi001 interface. ram capacity is 192mb. is this enough? what can i expect from increasing the capacity? i only use it in our rehearsal place, for recording demos or making good pre-productions.
thanx |
it should be.... check out he compatibilty page the link is on the left at the top of this page in the menu
Hola,
I have the same G4 than you, but I have 256 MB RAM. 192 is almost the limit, I recomend you 256 min. In respect with the perfomance, only another CPU is the solution. By the way, I'm very hapy with this setup. Chao... Maximiliano from Chile. |
Hi Guy
I suggest you 448 mo RAM It's better If you want to work with Virtual synth Protools eats a lot of Memory But 256mo is enough or 192mo You have a great configuration More memory doesn't accelerate your CPU and you won't be able to put more RTAS plugs
MACPRO BI 2,66 +5Go RAM+ OS 10.6.8 FRENCH SYSTEM + DIGI002 RACK Protools 9.06 www.myspace.com/alx002 |
Add more ram. We have 250mb allocated to PT and 200mb allocated to DAE.
I'm running Protools LE 5.1.1 on a beige G3 with only 192Mb under Mac OS 9.1
It's not been too bad with that amount of RAM, I created a trimmed down extension set to lower the system memory to around 23Mb, allocated an extra 8Mb to DAE over it's default setting and added 4Mb to the default memory allocation of protools. I think most people recommend allocating quite a bit of RAM to DAE, I'm adding another 128Mb soon to see if allocating more RAM to DAE improves performance. |
System Requirements and full System Setup | MadDogRunner | Windows | 2 | 02-25-2013 06:44 PM |
"No-Lo" System Requirements | moblues | Post - Surround - Video | 10 | 07-15-2008 05:29 PM |
system requirements | brandonstevens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-22-2008 05:09 AM |
System Requirements | scott__free | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-08-2001 10:20 AM |
System requirements | drumbeat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-16-1999 04:20 PM |
