Hey folks, I just ran into a bug today in which I cut a clip, hit ctrl+shift+A to analyze it to Melodyne, the Melodyne tab opened and... there's nothing there. I've tried clearing the melodyne on the clip and re-trying it, I've tried loading the full track, and it's just not happening. What's even more strange is that the melodyne notes appear on the clip exactly as you'd expect them to (with the bars going across matching the notes). I've got a screenshot where I zoomed way out in Melodyne to show that there's just nothing there, but you can see what I mean about the clip in this screenshot.
Also notable, I tried to recreate this issue with another Pro Tools session from the same album project (so similar folder structure, sessions created at the same time, etc), and it worked as it should. I can't seem to reproduce this outside of this session, but I'll update if I can get it to happen again Has this happened to anyone else? Anyone have ideas for a fix? I'm trying to force myself to use the ARA2 workflow to get used to it in case it improves, but between the dreaded "Saving ARA data..." window constantly slowing me down and now this, I've gotta say, this implementation is pretty awful so far. Computer/Pro Tools specs in the signature. Thanks in advance!
Pro Tools Studio 2022.9 macOS Monterey 12.5.1 Macbook Pro 2021, M1 Max, 64GB RAM Universal Audio Apollo x16 (x3) |
I am having similar - perhaps even worse issues - with Melodyne ARA2 in ProTools 2022.9.
If I select a clip, and right-click Melodyne->Edit I get a Melodyne popup window with hopelessly wrong Bars.Beats - plus a few solid bars - rather than Notes. This happens in (at least 2 sessions) where non-ARA2 melodyne worked fine. See screen grabs + system info in signature.
Pro Tools 2022.9 Windows 11 (up to date) UAD Apollo 16x + 8x Intel Core i7-8700@3.20GHz, 64.0GB |
Hi! David here from the Avid Community Team. Can you send me an email at mark.david.generato@avid.com so we can look into this? Thanks!
Hi David, appreciate your response here! I just emailed you with info, screenshots, and a session.
ARA2 is only for Melodyne? | s.d. finley | Pro Tools | 8 | 10-12-2022 07:25 PM |
ARA2 Melodyne support coming to next version of Pro Tools | noiseboyuk | Pro Tools | 80 | 09-28-2022 04:31 AM |
ProTools and ARA2 | thebeatinventor | macOS | 2 | 08-30-2022 07:37 AM |
ARA/ARA2 - why do I need them? | musicman691 | AAX Plug-ins | 31 | 04-30-2022 06:22 AM |
