Hello everyone,
I have the following problem: I would like to operate an EQ with the S6, for example. I take the track in attention (from the S6), touch an EQ button, the EQ opens in PT. Everything as I set it. Now I use the EQ and when I'm done with the settings and switch to another track using the Attention Knob. Although I have set "Close Window when no longer editing" under Workstation-General, the EQ of the first channel remains open. Only when I click on another channel in PT it will disappear, or if I use Strg+Alt +W Can't I configure this when used only by the S6? A second question: Is it possible that if I have channel 1 in Attention and the EQ is opened, for example, that the EQ in Pro Tools automatically opens when I click on channel 2 - if it also exists in channel 2? Best regards Stefan |
What do you have this set to? "Open Windows on Workstation When Knobs Assigned"
"Open/Close window when editing/Exiting" option and Cubase 11 | anason-records | Avid S1, S3, Dock and Control App | 7 | 10-28-2021 02:14 PM |
How to close plug-in window after editing | Mishabou | Avid S4/S6 | 2 | 04-15-2020 10:52 PM |
Shortcut for close plugin window | José Luis Díaz | Tips & Tricks | 11 | 02-02-2018 09:06 AM |
Window buttons don't close the window | porkipine | ProControl, Control|24, Command|8 | 0 | 05-02-2009 11:17 AM |
Can't Close Preferences Window | DavidMPierce | Digidesign Hardware & Software | 8 | 11-13-2000 09:23 PM |
