Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 07-01-2021, 11:28 AM
tomhartman tomhartman is offline
Default Sync Problems with Carbon Downstream
So, I have a ref audio track of a song. It is bussed to an AUX that feeds my master out. No plug ins.
I have a guitar track that feeds a GTR AUX which then goes to that same AUX that feeds the master out. Both the GTR track is in DSP mode (again, no plug ins) and the GTR AUX automatically goes into DSP mode of course.
On playback, 9 out of ten times the guitar track is not in sync with the click or the reference. The only sure way to make sure things stay in sync is to have the guitar track avoid going to the GTR AUX and go straight to the AUX that feeds them master, like the REF track does. I have seen this in cutting vocals as well, all of a sudden a playback shows the vocal out of sync. Fiddling around randomly (enabling, disabling DSP mode) sometimes helps.
Definitely something weird happening. Anyone else having sync issues?
Old 07-01-2021, 01:11 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Sync Problems with Carbon Downstream
Hi Tom,
-Is this with 2021.6? If so, did it also occur in earlier versions?
-Will you attach a screenshot of the session that clearly shows all the track routing?
-Which record mode are you in?
-In I/O Setup > Output what are the 'Audition Path' and 'AFL/PFL Path' assigned to? If they're assigned to an output like MON L-R and you switch that to 'no output/none', does that have any effect?
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 07-01-2021, 01:18 PM
Originally Posted by Kyle Splittgerber View Post
Hi Tom,
Screenshot:
https://www.dropbox.com/s/yob7o2qwm2...%20PM.png?dl=0
In this shot I went back to avoiding sending the EG1 and EG2 guitars to the E GTRS AUX and went straight to the Submaster Aux feeding the main outs.
This is with 2021.6 but happened previously as well. I'm always in Quickpunch Record mode.
I will check out the MON L-R and get back to you. It does seem rather random. When doing vocals it's a similar situation, as the vocal track is assigned to a LEAD VOX Aux and the on to the Submaster. Often the vocals get out of sync. Will keep hammering on this.
I just now played back a guitar track that was routed to the E GTRS Aux and it was fine. As soon as I put a second guitar track (also routed to that AUX) into DSP mode, the first track than had just played back fine, was now out of sync.
Old 07-01-2021, 01:41 PM
Thanks, Tom. Will you switch the routing back to the back to the problematic config, show Delay Compensation in the Mix window, then take another screenshot and post that?
Is there any change if you put the 'REF' track in Native Mode? Since that's just a playback track it doesn't need to be in DSP Mode. Also, is there any difference if you switch to Normal Record Mode?
Kyle Splittgerber
Berkeley, CA
Old 07-01-2021, 01:52 PM
New screenshot with Delay Comp
https://www.dropbox.com/s/9tn4ujmeg8...%20PM.png?dl=0
The REF got put in DSP mode just for kicks, it's usually not, I was fishing around trying things to see if it made any difference....
Old 07-01-2021, 02:00 PM
That screenshot doesn't have tracks in DSP Mode. Will you enable the relevant tracks and re-post? Thanks.
Kyle Splittgerber
Berkeley, CA
Old 07-01-2021, 02:05 PM
Oops...
https://www.dropbox.com/s/m4c8usx3vc...%20PM.png?dl=0
No delay showing. I will keep an eye on this and try to repro more...
Old 07-01-2021, 02:15 PM
Oops...
Sounds good. If you can find a consistent reproducible case, let me know. We'll take a look.
Kyle Splittgerber
Berkeley, CA
Using Carbon with Avid Sync HD? akhafaji Pro Tools | Carbon 1 01-18-2021 12:03 AM
Communication problems between Carbon and Pro Tools michenal Pro Tools | Carbon 7 01-11-2021 02:59 PM
Sync Problems rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2007 08:49 AM
Moving Everything Downstream hearttimes Pro Tools TDM Systems (Mac) 4 12-22-2005 04:44 PM
