Sorry if that title confuses anyone, I have moved over to Pro Tools from Cakewalk Sonar and I am not sure of the correct terminology, so I really don't know how to ask this question. So here I go.
In either play or record, the line that flows down the track over the track clips while in play or record, once it hits a spot where there is no more room on the screen to see the rest of the track clips, it just keeps going but the track clips don't follow and I can't see where I am at in the song. Cakewalk Sonar did this automatically. Is there a setting in Pro Tools (I am in 10) that allows the screen or whatnot to move along with the track view to enable you to see where you are at? Sorry if I am not asking that correctly. Trying to learn.
Edward Fenley "Either learn to endure, or hire a bodyguard." ~ Bruce Lee |
Look under "Options". There is a secondary menu to set the Screen Scrolling options.
Cheers,
Thanks a ton man!
No problem.
Moving clips when in Volume Track View ... | ptfigg | macOS | 5 | 02-28-2014 09:03 AM |
Multiple EQ Setting for Separate Clips on Same Track? | wackjaw | macOS | 13 | 04-19-2013 05:01 PM |
Plugins only working for parts of track (certain clips) | Jackmcollins | macOS | 2 | 01-02-2013 12:45 PM |
Location for track midi/audio clips? | Sorion | Windows | 5 | 12-27-2012 01:49 AM |
Fades Multiple Audio Clips - Same Track | tomsaboia | macOS | 0 | 09-11-2012 11:14 AM |
