I have some sd files that need the left and right channels to be reversed
how can i do this within sound designer I would appreciate any help- the material recorded is very important synths@earthlink.net |
I believe any Pro Tools/Mac setup can open SD II files. As for swapping L&R, probably if you rename the audio files(swapping the L and R at the end of the file names), that might be all you need. Since you can't have 2 files of the same name, probably you would take the file ending in L and change that to X. Then rename the right to end in L, then rename the left to end in R(instead of the X).
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Just listen to it with your headphones on backwards.
David J. Finnamore PT 2022.9 Ultimate | Clarett+ 8Pre | macOS 12.6 on a MacBook Pro M1 Max PT 2022.5 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Still Using Sound Designer 2 | Modi | Digidesign Hardware & Software | 22 | 10-19-2020 05:10 AM |
Sound Designer 2.83 simple question? | darren.h | Digidesign Hardware & Software | 8 | 07-21-2006 08:45 AM |
Sound Designer II & Sound Designer Universal | Grigory | Digidesign Hardware & Software | 0 | 04-28-2005 04:18 AM |
Sound Designer | NuBus | Digidesign Hardware & Software | 13 | 01-20-2003 10:03 AM |
i can't run my sound designer with my 001 | Golu | Digidesign Hardware & Software | 2 | 11-23-2000 09:34 PM |
