Should Digi Test work properly with Lynx Aroura Interfaces? I did a test and it said one of my Accel cards failed. But when I run a session it shows that card is using DSP for plug in's. So which do I trust?
Thanks in advance, Keith Moore
Pro Tools HDX 2021.6.0 Lynx Aurora 16 Ross Martin PCM4222 Ross Martin Super Beast Apple Mac Pro 8 Core 2.66Ghz 16GB RAM OSX 10.14.6 http://www.keith-moore.org |
![]() Quote:
You don't have to have an interface connected to run Digi test! run the test again without the Lynx connected. Check your flexi cable is connected well between the cards. see if that helps with the error message. Chris
Thanks I'll give that a shot.
The only thing that should fail when running DigiTest with an Aurora connected is the LoopBack Sync test. This fails with pretty much all 3rd party converters, however Lynx is going to be implementing this in the next firmware update for the LT-HD, along with a few other goodies.
Joshua Aaron President/Chief Eng. AudioLot/AudioLot Studios Pro Audio Sales/Consulting http://www.audiolot.com Follow AudioLot on Facebook |
![]() Quote:
Thanks, Keith
No, that won't make a difference on the card that the Lynx is connected to. If you want to ensure that all of your Digi cards are fine, disconnect all the interfaces and run DigiTest. That'll test the cards only. If all is well, then you're good to go. You can also just plug-in the 96 i/o and re-run DigiTest to see if all is well there too. Just remember that when the Lynx is plugged in, Loopback Sync will fail. If you are getting errors without the Lynx connected than you've got a problem on your hands. Otherwise, you are good to go.
New Lynx Hilo converter/interface - interesting product | nst7 | Pro Tools 9 | 2 | 09-19-2011 05:20 PM |
Help with new interface (Lynx Aurora) | LanceK | macOS | 0 | 03-21-2011 03:07 PM |
Options to interface the LYNX Aurora16 into proTools? | GrievousAngel | Pro Tools TDM Systems (Win) | 1 | 10-10-2010 07:30 AM |
Audio interface not recognised, Lynx Aurora problem | 2fly | Pro Tools TDM Systems (Mac) | 4 | 05-14-2007 09:49 PM |
digi 001 failed test 22 shared memory test | the originalman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-14-2003 08:31 AM |
