Old 01-24-2007, 09:46 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Audio Alignment Plug-in !!!!
Hi !!
Is the Synchro Arts VocALign the only plugin to align tracks ????????
Thanks!!!!!!
- Jesus Alvarado -
Keep the volume UP !
Old 01-25-2007, 04:37 PM
3JDamon 3JDamon is offline
Default Re: Audio Alignment Plug-in !!!!
If you're talking about time-alignment of two drum mics, for example, that's generally done manually, or there are the time alignment plugs that come with Protools 7.x, but those are generally used to compensate for latency imposed by plug-ins.
VocAlign does a much more complex process of aligning vocals so that passages start and end together and consonants occur at the same time, even if the vocal tracks are sung by different vocalist out of sync. It actually does a very good job, depending on the takes, but like Auto-Tune, it can lead to a more sterile impression if overused.
I don't know if there is another plug-in that does that.
Audio file alignment wgouldsby Pro Tools 9 2 06-23-2011 02:13 PM
Track alignment using TimeAdjuster plug Halstein Pro Tools TDM Systems (Mac) 4 10-29-2008 10:30 AM
Audio Track Alignment Phil Smith Tips & Tricks 1 01-10-2006 03:57 PM
Audio Track Alignment Phil Smith Tips & Tricks 1 01-10-2006 03:53 PM
The out of alignment audio problem.... Jack Ruston UK Pro Tools TDM Systems (Mac) 3 12-07-2005 11:39 AM
