Old 10-28-2022, 11:49 AM
bonzerboy bonzerboy is offline
Default Plug in for looking at EQ curves ?
Is there a plug in like plug in doctor to insert on a track and look at an EQ curve? I tried plug in Doctor but it did not see AXX plug ins. I would like to look at the difference of EQs at same settings and or match some settings
to try diffent EQs
Wow am I groovy or what
Old 10-28-2022, 12:52 PM
Benny_Cha_Cha Benny_Cha_Cha is offline
Default Re: Plug in for looking at EQ curves ?
Waves Q-Clone
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2022.12, MacBookPro i9 8-core 2.3gHz, 32Gb RAM, Mac OSX 12.6.1, SSD sample drive,
Neve 8816, HD Native Thunderbolt, Apogee DA-16X, Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 10-28-2022, 03:12 PM
nednednerb's Avatar
nednednerb nednednerb is offline
A potential way to test would be using a spectrum analyzer with infinite hold peak setting turned on. Then select a clip with one EQ rendered, then another EQ rendered, and compare the held peak simply by looking at a screenshot. I suppose multi-band, high SR analysis would give more visual detail, especially if differences are minor.
Note whether you can even hear the differences you see. Check extreme gains on quiet material for instance if you're interested...
You could also try inversion of polarity between the results and the starting point and between one result and another. See how much cancels out. Might give an idea on differences in the EQ curves at the attacks and decay moments in the audio, and in general any differences..
___
>> me: nednednerB //
||main gig: editing audio & testing software / 2nd gig: music software tutoring //
||software: Ventura 13.1 | PT Studio 2022.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB //
||devices: Focusrite Clarett 2Pre | some AT condenser mics | SM58 | Ableton Push 2 | 32" 4k LG secondary display //
||automation: SoundFlow | Keyboard Maestro | SteerMouse //
Old 10-30-2022, 06:01 PM
loopzilla2 loopzilla2 is offline
+1 for Q-Clone curve display.
That thing will absolutely null with the original hardware too... It's perfect for what it does.
HTML code is On
Midi CC curves cqd Pro Tools 2 10-28-2022 07:59 AM
Can Pro Tools Do Automtion Curves? Glo123 Pro Tools 12 13 09-24-2017 01:06 PM
Question About Velocity Curves SoundSmith323 Pro Tools 12 4 10-13-2015 04:14 PM
editing volume curves cc1 Pro Tools TDM Systems (Mac) 14 01-08-2008 09:18 PM
film eq curves, dvd eq curves ashish Post - Surround - Video 3 02-02-2004 05:17 AM
