Old 07-22-2022, 05:28 PM
mgw783's Avatar
mgw783 mgw783 is offline
Default tips on creating a region in protools
the answer to this is probably buried somewhere, but when i create a region on a track, to quickly add text to a region, is there a shortcut key rather than double clicking the region, it would be optimal to just hit enter, especially when your trying to cue on a time crunch. .. srry,, new guy.. thanks..
Old 07-23-2022, 08:28 AM
smurfyou smurfyou is online now
Default Re: tips on creating a region in protools
On a Mac it is SHIFT-OPT-CMD-R.
Not the easiest shortcut. I created an alternate with Keyboard Maestro to create the clip group and rename in one go. Or if you're on PT 2022 you could reassign the shortcut.
~Will
Old 07-23-2022, 05:11 PM
This is a very confusing post on several levels:
#1- A "region" is an old term(from PT 10 and older) for an audio file or midi file. We now call them "clips".
#2-Usually, you don't create a clip, you record a clip, be it audio or midi.
#3-I'm guessing you are trying to name the clip(region)? Unlike smurfyou, I didn't know there was a shortcut(I just double-click on the clip). Having said that, are you naming your tracks BEFORE you record? This is a very good habit to learn. Naming the track will impart the track name onto the clips(with numbers once there are multiple clips or takes on any track).
If none of this is helping, come back with a clearer explanation of what you want to do
BTW, given the key command that smurfyou posted, it looks like the 3 modifier keys+R, so on Windows, it SHOULD be Ctrl+Windows+Alt+R. For me, since I have one hand on the mouse most of the time, the double-click feels faster, but not everyone works the same
Old 07-24-2022, 07:09 AM
I was trying to infer since OP was cueing something they were creating empty clip groups. Make an empty selection, hit OPT-CMD-G and you get an empty clip that uses no disk space and can be used for cues or notes and edited like any other clip.
~Will
Old 07-24-2022, 08:05 AM
zoff zoff is offline
Never thought of that. Thanks for the tip.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 07-24-2022, 08:19 AM
Hmmm, this raises more questions for me;
1-are you sure this blank clip uses no disk space?
2-can you give me a reason why you would do this?
Still learning
Old 07-24-2022, 06:11 PM
Yes since it is a clip group it contains no media, it just exists as an empty clip.
It's common in film post. For cueing ADR and Foley. It solves many of the limitations of markers. They can easily be edited, trimmed, sorted by track, exported in an EDL....
~Will
Old 07-26-2022, 11:51 AM
mgw783's Avatar
yes the region, I need to add text box to popup without double clicking on it.
Old 07-28-2022, 08:33 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Edit your keyboard shortcuts.
Or as the person above said, it is already all three modifier keys plus R
You seem to have missed the answer and restated your question plainly.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 09-20-2022, 02:22 AM
Chevron Chevron is offline
A quick way to also add a clip/region is to use the key command OPT-SHIFT-3, which creates a blank audio clip or a blank MIDI region.
Add CTRL to the command CTRL-OPT-SHIFT-3, and this creates an audio clip with a 1Khz sine wave
Nice one on the OPT-CMD-G to create a group, I thought this would just be for existing clips but handy to know you can use it in a blank space....
Pro Tools Studio 2024.3| Eucon 2023.11 | Mac OS 14.3.1 | Soundflow | Streamdeck | 16" Apple MacBook Pro M3 Max 16 Core 64 GB RAM | 2020 MacBook Pro 13" M1 16 GB RAM | Hackintosh i9 9900KS 32 GB RAM
MIDI punching not creating New Region [email protected] Pro Tools HDX & HD Native Systems (Mac) 3 06-21-2018 12:16 AM
creating a blank region [solved] lblanks240 Pro Tools 12 5 01-04-2017 11:41 PM
creating fade on muted region daniri Tips & Tricks 2 12-23-2006 08:45 AM
Tips on creating a good outdoor reverb. Droog Post - Surround - Video 12 03-09-2005 09:36 AM
Creating Region between 2 Markers fader8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2003 06:45 PM
