Old 10-29-2021, 02:10 PM
kkfaudio kkfaudio is offline
Default possible bug?
I've had 2 custom buttons programmed to Artist control for quite some time that has stopped working with the 2021.10 update.
It's a simple "shift/control/up-arrow" key command repeated 4 times to allow a one button hit to adjust clip gain by 2dB. I have the opposite with down-arrow to do clip gain down.
It doesn't seem to work as of this morning's update.
I have not updated PT yet - still on 2021.7 as I'm in the middle of tons of projects. iPad updated to Control 2021.10, so had to do Eucon. (note to self, turn off automatic updates on iPad.)
Seems like the key commands are not being recognized when sent from Eucon, as it works fine when using the keyboard.
Do I need to update PT? Seems like a few things require that, so maybe this is lumped in?
Not the worst thing in the world - but it's a command I use often...
Thanks,
Kevin
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 10-29-2021, 03:33 PM
BScout BScout is offline
Default Re: possible bug?
upgrading Pro Tools to 2021.10 won't fix it.
Something else going on with Eucontrol/Eucon on multi-key commands.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Pro Tools Ult 2022.12, RME BBF ProMac Mini 14,12 - 12 core - macOS 13.2RAM 32GB, SSD 4TB, GPU 19 core
Old 10-29-2021, 03:46 PM
I suspected other key commands like that may be affected. Thanks for the confirmation.
Kevin Ferrier
Old 10-31-2021, 01:17 PM
EddieJones's Avatar
Can you check if this is to do with the modifier "Control" Also post which OS versions you are on please?
Old 11-01-2021, 05:40 AM
Hi Eddie.
Catalina 10.15.7
Seems to be "control" key. Tried making a couple of key commands like "Control numpad 6" for playback which didn't work, but "option 6" did bring up the clip effects window.
Thanks,
Kevin
Kevin Ferrier
Old 11-01-2021, 09:30 AM
EddieJones's Avatar
Looking into this, I can reproduce now on Windows too.
Old 11-04-2021, 06:33 PM
pweinrobe pweinrobe is offline
hi i just want to note that today all my S3 modifiers stopped working
s3 up to date
running MacOS Montery 12.0.1
pro tools 2021.10
eucon 2021.10
all modifiers keys on S3 are not working. tried multiple S3/Pro Tools/Computer restarts....
Old 11-04-2021, 07:59 PM
EddieJones's Avatar
s3 up to date
pro tools 2021.10
eucon 2021.10
We have already fix it and will be in 21.10.1 next week. The Control Modifier was sending out Command instead ;-/
Old 11-04-2021, 09:34 PM
amazing!
just to be clear: on the S3 it wasn't just a control/command issue. all modifiers weren't working (or maybe were sending the wrong thing?)
thank you!
phil
