Old 11-15-2007, 02:33 PM
uno1234 uno1234 is offline
Default What is \"Restore Cut\"?
I'm trying to map a sample that I dragged into structure from the pro tools timeline.
When I change the start and end points, the sample doesn't play back at all.
When I right-click in the wave window and choose "Restore Cut", I'm able to move the start and end points and get the proper playback. However, when I moved around the start point, I got a "poof" crash. Also, it seems to show the entite pro tools track where the sample came from.
Changing the start and end points of a sample within a factory patch works properly.
Anyone?
Old 11-16-2007, 05:38 AM
Default Re: What is \"Restore Cut\"?
I'm trying to do this:
http://www2.digidesign.com/PTA/PTAcc...ml?langid=100&
At 1:39 in this video, he changes the end point of the sample. If I do this on my machine, the sample will not play back.
If I choose "Restore Cut" from the Right-click menu within the waveform, I can then change the points and continue to hear playback. "Restore Cut" is not described anywhere in the user guides.
Clearly something is broken, I'm doing the exact same thing he is doing in the video.
Help with MEZZO restore chuckbutler Pro Tools TDM Systems (Mac) 63 09-17-2019 09:21 AM
Restore Point? Funkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-24-2010 05:08 AM
How do I restore my inputs Makingamonster General Discussion 2 04-21-2010 07:35 PM
Please restore my sanity Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2003 02:13 PM
How to restore session? Little Yann 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-04-2002 02:05 AM
