Old 04-02-2004, 11:20 AM
JNS JNS is offline
Default Clocking MIX system with Apogee AD-16
Hi. I'm looking into purchasing an Apogee AD-16 (not AD-16X) and was wondering about clocking issues. I have Mix system with 3 888/24 interfaces, a Rosendahl Nanosyncs unit, and ADAT Bridge. I was wondering if I should (1)still run master clock out of the Nanosyncs unit to the AD-16 and then from the AD-16 I would send clock to the 888s and daisy-chain them, OR (2)forget the Nanosyncs and just use the AD-16's clock and daisychain the 888s, OR (3)avoid daisychaining the 888s and run separate clock lines to the AD-16 and to each 888 from the Nanosyncs?
Also, is there any problem with using the lightpipe connections on the AD-16 and going through the ADAT Bridge OR should I go ahead and invest in the AES output expansion board and avoid the ADAT Bridge lightpipe setup?
I will greatly appreciate any input or other suggestions on these issues.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 04-03-2004, 07:45 AM
JNS JNS is offline
Default Re: Clocking MIX system with Apogee AD-16
ttt
Old 04-03-2004, 11:57 PM
kurt's Avatar
kurt kurt is offline
You could feed clock from Apogee AD-16 to Nanosyncs & than from Nanosynsc separate clock lines to the rest.
Apogee AD-16 thru ADAT Bridge should be just fine. Going AES/EBU saves some DSP.
(If you skip ADAT Bridge.)
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 04-04-2004, 09:30 AM
JNS JNS is offline
Thanks, Kurt. I never thought of going the other way around and letting the Nanosyncs be a clock distribution box. Duh. That should work fine. Also, regarding the lightpipe vs. AES issue, someone mentioned to me that lightpipe is limited to 20-bit which I think is correct. Therefore, i would lose something when going through the ADAT Bridge. Might somewhat defeat the purpose of using the separate converters. I will probably go AES all the way.
Jeff
Old 04-04-2004, 09:47 AM
kurt's Avatar
Hm, not exactly so.
1.) Put the Nanosyncs Ref. to the WORD. Than Nanosyncs will be slave to Apogees clock (not bad), & you will have enough clock outs to the rest of the system.
2.) First generation of ADAT Bridges was 20-bit. If your ex. is not 24-bit (Look at the logo) than you can upgrade it or buy used (cheaper.)
Apogee AD-16X and HD I/O clocking issue track Pro Tools HDX & HD Native Systems (Mac) 7 04-18-2014 08:28 AM
Another Clocking question -- 192/SSL/Apogee greenwall Pro Tools TDM Systems (Mac) 3 07-05-2010 02:45 PM
Clocking to an Apogee Big Ben one 192 and a legacy alex3368 Pro Tools TDM Systems (Mac) 2 10-22-2006 01:52 PM
Clocking Mix 24 system from Apogee Rosetta 200 slingsby Pro Tools TDM Systems (Mac) 0 03-24-2006 06:50 AM
Apogee Rosetta 800 clocking thin ice Pro Tools TDM Systems (Mac) 30 08-26-2003 09:18 AM
