Old 09-23-2021, 02:39 PM
dkean dkean is offline
Default Delay/latency on S1 screen
I have 3 S1s and a ProTools Dock. Everything works fine except on one S1 screen I have a metering issue. I'm using an iPad on the dock and 2 iPads and an amazon fire on the 3 S1s. There is a latency/delay on the right hand S1 screen (iPad). If I bank the channels to the other screens the latency goes, it only affects one screen.
I've rebooted eucon/ipad and checked firmware, iPad OS and they are all running the same configuration. The small yellow meters on the S1 are reacting properly, it's only on the iPad screen that there is a metering latency, sometimes a freeze.
Any ideas what could be causing this?
Thanks
Douglas
Interface Studio
Mac 1 System
CubasePro 11, Pro Tools 2021.7
MacPro 3.5Ghz Six Core Intel Xeon, 64Gb ram,
OSX 10.15.17
Avid Duet, 3 x Avid S1, ProTools Dock, Ableton 10, Reason was 12, NI Komplete 12, NI Komplete Kontrol S61 and S88 Mk2
Mac 2 System
ProTools 2019
MacPro 3.5Ghz Six Core Intel Xeon, 16Gb ram,
OSX 10.13.3
Digi 003 rack
Slate Raven MTi2, Avid MC Transport
Old 09-24-2021, 10:33 AM
EddieJones's Avatar
Default Re: Delay/latency on S1 screen
Can you check what wifi networks they are connected to? Is one on 2Ghx and the other 5 ?
Old 09-24-2021, 03:42 PM
Thanks for your response Eddie - I think that's fixed it.
For anyone else that has this problem, I have a 4 port Netgear switch that all the S1s and Dock go into that then ports to a Neatgear R7000 router. I checked on the routers wifi setup and in the advanced setup there was a checkbox for
"Enable Smart Connect - Let the router intelligently select the best WiFi band 2.4 GHz or 5 GHz for your WiFi connections. Smart Connect requires the 2.4 GHz and 5 GHz networks to use the same WiFi network name (SSID), security options and password."
I unchecked that and everything works OK now, no latency!
Thanks again Eddie for your astuteness.
Interface Studio
Mac 1 System
OSX 10.15.17
Mac 2 System
ProTools 2019
OSX 10.13.3
Digi 003 rack
Old 09-27-2021, 09:36 AM
EddieJones's Avatar
Yes, that is not only bad because you can end up on the slower speed, but it can also switch live and break the EUCON connection.
Strange Delay Comp Figures (with screen grab) Ru_C Pro Tools TDM Systems (Mac) 6 01-29-2012 07:12 AM
Delay/Latency? Cal D Pro Tools M-Powered (Win) 0 10-29-2011 10:40 AM
Latency / Delay variation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-26-2007 01:15 PM
Adjusting audio to video delay for Plasma screen ? Aquarius Post - Surround - Video 0 05-13-2004 02:46 AM
Huge Delay to 5.0.1 splash screen potatohead Pro Tools TDM Systems (Mac) 3 08-11-2000 12:27 AM
