Batch Clip Rename shortcut
Batch Clip Rename shortcut (Control + Shift + R) does not work on my Mac(catalina, PT2021.7).
Does anyone know why it's not work ? Last edited by norao; 09-22-2021 at 11:43 PM. |
Re: Batch Clip Rename shortcut
Do you have the clips selected prior to using the shortcut?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Are they showing in the clip bin? You probably have an uncleared search in the clip bin (clear find = shift-cmd-d).
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 Last edited by Rich Breen; 09-23-2021 at 12:13 PM. |
Thank you for reply.
Of course I selected clips. If I don't select clips, I can't click 'Batch Rename' from pulldown menu. |
I know.
After use Find Clips (shift + cmd + F), we can't even Rename (shift + cmd + R) without select. |
Sorry - had to ask! I'm not in front of my DAW right now so I can't test - but have you tried changing the keyboard focus? I'm not sure that's the solution, but maybe. Have you tried trashing preferences?
Not sure if the is what your issue is.
Batch Clip will not work if you ie: 1. take clip A and cut it up into many pieces (it will see it as one file still). 2. You first have to first turn the individual segments into new clips using consolidated or and audio-suite process 3. batch rename will then be available |
Of course clips are not files so the root file won't get renamed (even if you try to force a batch file name afterward -- which is the only way to apply a batch clip rename to a file.) In that case you need to consolidate clips into files first, do batch clip rename, and then do file rename (Avid, c'mon give us a checkbox in batch clip rename so we don't have to do that stupid step.) This is just one file sliced into clips and nothing else done to it before batch renaming.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Make sure to check "Show Auto-Created Clips".
Batch track rename | Frank Kruse | Post - Surround - Video | 3 | 10-09-2019 09:23 AM |
Batch Clip Rename not renaming audio files - just clips PT 2018-3 | MixerGuy | Pro Tools 2018 | 12 | 02-09-2019 08:45 AM |
Batch rename is welcomed | DJ Hellfire | Pro Tools 12 | 11 | 10-26-2017 12:58 PM |
batch rename regions? | dboles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-31-2015 11:44 AM |
Rename Clip shortcut changed? | JWalkerPostAudio | Pro Tools 10 | 0 | 01-10-2014 03:25 AM |
