Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-19-2021, 05:47 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Carbon- Basic Questions..
Originally Posted by abc1mce2 View Post
I can assume you use a plugin controller for your M7's (M7 link or M7 Control) for recall purposes?
Actually No (not yet anyway ) Understanding that I am a private user and do not record anyone but myself. I have found the 4 preset buttons handle the most of the basic variations I use for reverb, and is more than sufficient. (which is mostly singer songwriter type productions )
I have the basic parameters and any user adjustments (like pre delay etc.) preset and just change the amount of send depending on the specific instrument or vocal sound I am after an how I want it to sound in the mix ( and of course, the send amount saves and recalls with the session) . And like you, if I want something really noticeable for effect I sometimes just use a reverb or delay plugin directly on the track
For example in this original music video I did recently with the Carbon.
I am using about as much reverb effect on the vocal as I am likely to use (M7 Sunset Chamber preset with pre delay added ) then also automated to bypass in out,,, directly on the vocal track I am using the PT stock Tape echo plugin.
https://youtu.be/PN3WxHxWwCo
System :
Avid Carbon interface , PT Ultimate 2021.6 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 09-22-2021, 04:47 AM
darkwavo darkwavo is offline
So has anyone determined whether the ADAT connection provides the low latency DSP (lightning bolt) capability?
Thanks !
Old 09-22-2021, 06:42 AM
dominicperry dominicperry is offline
Thanks !
Yes, it does, the 8 ADAT channels work just like the 8 analog inputs.
What you do need to think about is the difference in A/D timings of the converters in the Carbon compared to the converters in whatever ADAT expander you are using.
Dominic
Old 09-22-2021, 09:14 AM
Dominic
Thanks!
But that’s only in the case that I would be recording the same source (drums) through the separate converters and say therefore have timing issues. But if using just one converter at a time would be fine …?
Old 09-22-2021, 09:23 AM
Thanks!
There will (probably) be a difference in timing between the analog channels and the ADAT channels, but it will be in the region of less than a couple of milliseconds. It might be substantially less. Whether you can hear it or not depends on whether you can hear it or not! With very short differences, comb filtering is the most likely issue. The problems of bleed and phase alignment when multi-mic'ing a drum kit are much more likely to need attention than slight differences in converter speed.
  #16
Old 09-22-2021, 12:08 PM
Ok. But that issue ((comb filtering)) would only occur if crossing over musical duties between the two converters— like a drum set I/o or a duplicated track occurring on each converter simultaneously. If I record everything on a single converter on the way in and mix in the box , then there is no issue..?
  #17
Old 09-22-2021, 12:09 PM
Another question,
Is it necessary to use the DB-25 input if I want to bypass the line amp? Or will the TRS combo input also give this option ?
  #18
Old 09-22-2021, 12:16 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Another question,
Line input gain bypass is available for both connectors types.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #19
Old 09-22-2021, 12:18 PM
Yes, comb filtering is basically from using 2 (or more) mics on one source. And you can get it from different mic distances, regardless of converters.
  #20
Old 09-23-2021, 02:15 AM
Ok thank you. Is there any advantage to using to DB25 input as opposed to TRS on the combi Jack for connecting an external mic pre etc ??
Thanks !
Carbon pre-purchase questions Bennett Paster Pro Tools | Carbon 8 08-13-2021 10:54 AM
Questions on Carbon Armando Pro Tools | Carbon 13 07-16-2021 11:40 AM
Basic questions about 11R rublalup Eleven Rack 3 01-27-2014 07:41 PM
Newbie questions on laptop PC selection - basic questions - thanks... half drag Windows 0 01-04-2011 01:12 PM
...some basic questions needing basic answers aponceenrile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2010 10:48 AM
